Results 1 to 13 of 13
Thread: New sanitizer eliminates the need for chlorine FINALLY!
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    605
    Cool New sanitizer eliminates the need for chlorine FINALLY!
    I just read a press release for a new Mircowave sanitizer for pools that guarantees to sanitize your water and kill all pathogens with 3 milliseconds. It also heats your water when power is increased to 3.1 gigawatts of output, the maximum output of the Microwave accelerator. In addition the new company has released a pool filter that is supposed to be 3000 times more efficient than DE. It is similar to reverse osmosis but allows a much higher throughput by using the membrane from a bulls testicle. I might buy stock in this new startup!
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Apr 2013
    Sacramento, CA
    2,769
    Re: New sanitizer eliminates the need for chlorine FINALLY!
    I wonder what the increased demand for Bulls testicles will do to the price of my steak at Outback?
    Donldson's Avatar
    NW Ohio
    2,917
    I am limited to only 1.21 gigawatts, can I still heat my water?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    aPRIL foOls
    Factory Warranty Station for:
    Oct 2012
    605
    Last year on April Fools i had an idea to photoshop a microwave oven with some pvc plumbing coming out of it and post it this year. Fast forward 1 year and I remembered that idea. Too late for a photoshop session but I had to post something since I didn't see any hijinks this year.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,073
    Quote Originally Posted by ComputerGuyInNOLA View Post
    You didn't look hard enough
    I can't shock my pool
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    What? It's a joke? I've been microwaving my pool water for years! Dang it!
    Jul 2015
    Central Valley CA
    1,109
    Quote Originally Posted by Donldson View Post
    Yes you can still heat it but only if you pump can get the water to 88mph.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    DFW, TX
    24,514
    The only way I can get my water to 88 mph is in my pick up truck. My tractor only goes about 10.
    I'm working on a new cyanuric acid reducer. It's antimatter cyanuric acid. You just add the amount you want to reduce the cya by and when the antimatter cya connects with the matter cya they're both annihilated and become pure energy. There are only a few "minor" details left to work out and then I will begin selling it. As a side benefit the energy released will heat the pool.
    Anyone wanting to invest in the product can contact the head of investor relations Mr. Charles Ponzi.
    Support the site
    JoyfulNoise's Avatar
    May 2015
    13,254
    Quote Originally Posted by JamesW View Post
    He must work in the law firm of Dewey, Cheetham & Howe....
    (Gosh I miss the Car Talk guys!)
    Matt
    Ponzi is the guy who the Ponzi scheme is named after. Also, I think that he was on the tv show Happy Days.
    Support the site
    DFW, TX
    24,514
    Aaaayyyyy!
