Thread: Sinking Concrete Repair
    Jul 2014
    Joplin, Mo
    33
    I drained my pool this year to try and take care of some maintenance that I have been putting off but I am not sure where to start on this sinking concrete. I know there are companies that will straighten the slabs but that will cost me a fortune as there are probably 15-20 10' sq slabs that will need to be moved and I am afraid it will mess up the french drains anyway.
    The concrete has pulled away from the tile by 0.5"-2". Can I fill this with silicone? Should I have a concrete guy come look? Do you guys have another idea?
    22,000ish gallon concrete pool.
    Taylor K-2006
    Sand Filter
    Joplin, Mo
    Apr 2013
    Sacramento, CA
    2,769
    Re: Sinking Concrete Repair
    I think what is happening here is your coping and deck is separating from the Bond Beam of your pool. Even while the pool is empty.
    Was this true when the pool was full?
    Is this on all sides of the pool?
    Is this a permanent condition or does the gap change seasonally or vary by some other factor like who is Governor of Mo?
    As it is that is too big a gap to span with caulk.
    More pictures of the overall pool would be good.
    Jul 2014
    Joplin, Mo
    33
    This sinking is there full time and only on one side of the pool. I ended up filling it with some sanded grout and if you had never seen it before you might say "did a blind man grout your pool?". But knowing how bad it looked before I grouted it I would say it is 40% better...
    Taylor K-2006
    Sand Filter
    Joplin, Mo
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Is the pool sinking or is the coping being raised somehow? Is the coping and deck 1 piece or is the coping separate?
    Jul 2014
    Joplin, Mo
    33
    The coping is pushing up. There was an enclosure that sat around it for 30 years pushing weight on the back side of the slabs and lifting the pool side. My thought right now is to just build a deck over it in a year or two when I have the $.
    This is an old pic of an issue you guys helped me solve
    Taylor K-2006
    Sand Filter
    Joplin, Mo
    wjr75's Avatar
    Jun 2013
    IL
    836
    Our pool builder told us once that the coping actually floats compared to the main pool. Not sure what caused yours to float up but may have been the pressure on the outer edge. Not an expert so hopefully there may be a way to let it settle down. Good luck.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
