Thread: Website mot responding 4/1/16
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    I keep getting this message:
    This site canít be reached
    Pool School - TFP Home Page took too long to respond.
    ERR_CONNECTION_TIMED_OUT
    And when I do get the website after a refresh, it hangs.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Website mot responding 4/1/16
    April Fool's?
    No issues here for me so far.
    Isolated Spa - 345 Gallons
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    I can get to everything except that page Hmmmmm
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Loads fine here now
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    No issues here...
    Essential Links:
