Results 1 to 8 of 8
Thread: Advice? Moving deck from 30' AG pool to our 27' AG pool
    Jun 2015
    Quarryville/PA
    58
    Hello! Happy Spring. This weekend we are moving a 3/4 surround deck from a neighbor's (no longer existing) 30' pool to our new 27' pool. Any tips or useful info on making the conversion would be appreciated!
    27' round ~ preowned ~ beginning install ~ replacing smaller pool
    klynch494's Avatar
    Aug 2015
    Twin Cities/MN
    96
    Re: Advice? Moving deck from 30' AG pool to our 27' AG pool
    Lift with your legs, not your back!
    ~Kevin (MN)
    13.5k gal, 24' Round AG Vinyl
    2HP Waterway Pump, 200sqft Hayward Element Filter
    BBB Method & AuquaSmarte Inline Chlorinator, TF-100 Test Kit
    Kevin, TFP Believer & Supporter
    (Yup, I drank the pool water)
    13.5K gal, 24' Round AG Vinyl, TF-100 Test Kit
    2HP Waterway Pump, 200 SqFt Hayward Element Filter
    Recommendations: Pool School, TFTestkits & Pool Math
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    patients and plenty off them It is going to be a pain but when your done you will love it..
    Aug 2014
    Houston tx
    2,525
    Lots of patients would certainly cut down the installation time.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Jul 2013
    Fletcher, OK
    3,353
    LOL, I have never said I could spell
    Casey's Avatar
    SW PA
    10,457
    You may find that the 30 will have a big gap around the 27 n may need modifications.
    Jun 2015
    Quarryville/PA
    58
    We plan on modifying. Just didnt know if anyone had an easy way to do the math! Have some heavy equipment and hoping to bring in 2 pieces....i know.😬
    And thanks a lot for the patience advice. Lol....not exactly the words of wisdom I was looking for!
    Also, we need to finish around the pool. I've been bouncing around the site and see many people's ideas, but what are the MUSTS for that foot or 2 that butts up against the pool? We do have a metal base channel and walls. So I'm thinking heavy black plastic or rubber roofing material a few inches up the sides and then stone. Is that all there is to what is referred to as "backfilling"? We do have about a 3' slope a few feet behind the pool so we will do the obvious with drain tubes to shun the rainwater around the base of the pool. It would be easier to literally backfill and level that area but it's my understanding we do not want dirt a foot or two up against the wall.....I will post a picture.....
    Casey's Avatar
    SW PA
    10,457
    You'll want a way to divert water if there is any collection. Mine doesn't collect rain water even though it's basically in a hillside. I got lucky.
