Page 1 of 2 12 LastLast
Results 1 to 20 of 35
Thread: Too much Chlorine
    Too much Chlorine
    Argh. I wasn't thinking clearly and tested for chlorine wrong while trying to shock with bleach. I thought my algea problem was so bad it was consuming what I was putting in so I kept putting in more.
    I finally realize somethings not right and start testing correctly, only to find that I'm now at 50+ppm! This was Sunday and now 5 days later, it still does not appear to be below 50. We've had a lot of cloudy days so I'm assuming its not coming down much.
    Looks like my options are 1) Keep waiting, but I need to get this right by next weekend so I have a full week to get rest of the chemicals right before a pool party, 2) drain and fill (20000 gallons, obviously not preferred!) or 3) Jack's Magic, etc, which best I can tell will cost $60 or so.
    Am I missing any other options?
    ETA: I have a heat pump I could turn on if that would help
    ~17,000 Gallons, IG-pebble, DE, SWG
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Too much Chlorine
    What is your CYA level?
    (Don't worry, everyone's done something like this at one point or another.)
    Edit: How are you testing? End Edit
    Casey's Avatar
    SW PA
    10,422
    I was just gonna ask the same thing.
    How bout a full set of numbers with that outrageously high chlorine? How many gallons did you accidently put in the pool?
    PH was near 8 which I started bringing down but now cant test for it of course
    TA 110
    CH 380
    CYA 10-20
    Salt 3550
    At this point I'm using the OTO test. 1 drop in 10ml turns orange. I was (incorrectly) using the Taylor kit which uses DPD Regant 1-2-3 (I was testing after 2, not realizing that I needed to use 3!)
    12 182oz jugs of 6% bleach were used to get here
    Thanks guys!
    Feb 2008
    Denton, TX
    5,061
    Yikes!
    So, 12 jugs of bleach with 182 oz each...that's a total of 2194 oz. of bleach. Assuming that it is 6% bleach, that raises your FC by 52 ppm. I would hazard to guess that this is probably not a good thing for the equipment. Would anybody suggest that maybe a partial drain and fill is in order or can they just let the sun take care of it. That's really high!
    Casey's Avatar
    SW PA
    10,422
    OMG. Atleast you don't have a liner pool.
    30,403
    YOur CYA level will have a significant effect on how quickly it comes down. 10-20 CYA is an unusual test result. Let us know how you're testing.
    Meanwhile, let your FC come down on it's own. it will not take as long as you think. In fact, if your CYA is less thantwenty, I believe it will decrease quite rapidly........a couple of days.
    The heat pump nor Jack's magic will do no good.
    I don't think you are in as bad of shape as you might believe.
    Once your FC gets down to 10 or so, post a full set of test numbers and you'll get good advice on what needs attention.
    Of course, accurate testing and dosing is a key ingredient in the pool care methods we teach here on the forum. I realize you know that but it is a reminder to all of us justy what BBB is all about
    Apr 2009
    South of Houston, Texas
    18
    Why is a CYA test result of 10-20 an unusual reading ? I think he means its just hard to tell sometimes when the black dot is not visible anymore. I sometimes shut one eye, then cant refocus, and its like is that a black dot or a mirage lol. I just did my first CYA test and I think I posted about the same, 10-20, wasnt really sure when the dot fully dissappeared.
    IG pool gunite/Plaster, 33 x 20, 20000 gal., 4.5ft-5-3.5ft, Triton FNSP-36 DE filter 36sqft 90gpm 43200 in 8 hrs, WhisperFlo Triton 1.5HP, Polaris 280 with booster pump, and a Dog that loves to swim,South of Houston.
    30,403
    The test only goes as low as 20....some view tubes only as low as 30. New testers frequently have troubles with that test and it's a good idea to reconfirm their results.
    Butterfly's Avatar
    South Carolina
    10,045
    Many of us have had problems learning how to read the CYA test!
    See if this visual helps (scroll to bottom pf page):
    http://www.taylortechnologies.com/Chemi ... ntentID=44
    You're done SLAMing when:
    Looks like I'm in the clear. For some reason my OTO test keeps suggesting Chlorine is super high (a 5 ml test calling for 5 drops of OTO) in that I can add just one drop to the 5 ml sample and it goes straight to an orangish color which made me believe it was 25+. HOWEVER, the Taylor DPD test reads 2 ppm. I actually have a second Taylor kit I pulled out and it gave the same 2ppm result.
    So my numbers are now:
    FC - 2
    TC - 2
    PH - 7.6
    TA - 80
    CH - 320
    CYA - 30 (I retested and feel better about this number. The 10-20 was from earlier, outside, when it seemed to disappear only when I got to the very top of the test tube)
    Agree with this approach now?
    1) Take TA down from 80 to 60
    2) CYA up to 80
    3) Chlorine up to 3 (SWG)
    4) Add Borates
    11,969
    So long as your FC is holding overnight, your CC is .5 or less and your water is clear, that is an acceptable plan.
    Jan 2009
    Cupertino, CA
    1,966
    With my TF100, the FAS-DPD and OTO are always in the same ballpark, as far as I can tell (I find it hard to distinguish 3 from 5 in the OTO test). But the DPD from the old kit is invariably lower, I no longer trust it at all. YMMV.
    --paulr
    BBB "Intermediate Swimmer"
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    900
    Quote Originally Posted by lurch
    TA 110
    CH 380
    CYA 10-20
    Salt 3550
    Thanks guys!
    Lurch,
    I think you were using the taylor correctly...5 drops of DPD from bottle 1, then 5 drops from bottle number 2 tells you your chlorine level. The last bottle tells you your total chlorine...TC -Fc = CC you know that...but I think from what you were saying above, you were using your taylor correctly...You don't alway have to use bottle number 3 just to get your CC reading. Does that make sense or am I misunderstanding what you are saying...I use the Taylor DPD and I don't always use the 3rd bottle maybe twice a week to check combined chlorine.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    Well, I just found this at the poolforum which is making me question it all again!
    OTO only tests Total Chlorine but can read chlorine at high levels (color is orange to brown when chlorine levels are very high)...problem is that most OTO kits only go up to about 5 ppm on the color comparator. It is good for quick daily checks on your pool or to make sure that you have chlorine if a DPD test bleaches out. OTO turns yellow if chlorine is present. Some OTO kits tell you it will read Free Chlorine if you do the reading within 15 seconds but I would not trust these results.
    DPD can read both Free Chlorine and Total Chlorine. It's biggest drawback is that it bleaches out (turns colorless) at chlorine levels above about 10 ppm or so. This might lead you to believe that there is no chlorine in the pool when actually the level is high. DPD turns pink if chlorine is present.
    So, perhaps I was using DPD correctly, but the results were bleached out making me think the chlorine had been used. Still doesnt explain the current results, though, as 5 drops of 1 and 5 drops of 2 give me a obvious result of 2 ppm, while the OTO still reads off the chart with just 1 drop.
    Your results are confusing. I suppose the FC level might actually be 2, and the OTO test could be showing a really high CC level.
    Just went and did another DPD and now its showing 5ppm. SWG is off so there is no way it could be going up. I think what I may be seeing is a reduction in the bleaching effect as the Chlorine is coming down, but it's still very high (25+). I'm back where the thread started, but it looks like we may have a sunny day today which would certainly help!
    This is one of the situations where having a FAS-DPD chlorine test really helps!
    It is a little unusual for the DPD test to only partially bleach out, but it can happen. One way you can get a little more information would be to try the DPD test with dillution. To do that you mix the pool water with an equal amount of chlorine free water (distiller water for example). Then do the test with that and multiply the result by two.
  20. Back To Top    #20
    You might want to make sure your reagents are not too old. I was getting a no chlorine reading with my reagents R0001 and R0002 from my Taylor kit. These bottles were stored inside but were about two years old. I bought new reagents and got a FC 3 using the same water sample I got a no chlorine reading from with my old reagents so these reagents do go bad over time.
    Pool Size 10,000 gallons
    Sand Filter
    In Ground "Pebble Tech" (plaster)
