Thread: Hose clamps leaking
    Mar 2016
    Greenville, SC
    16
    Hose clamps leaking
    Hi, I'm trying to open my pool for the spring. Yesterday we reattached the hoses by simply sliding them in place and tighting the hose clamps ( using the same hose clamps and hoses from last year). We filled the pool back up and tryed to run the system but there are three leaks at three of the clamps. We already tightened the clamps as much as we could, but they still leak. Are we missing something?? Are we supposed to use plummers tape? Or replace the clamps every year? We just got our pool last June and everything was installed by a profesional so now we have no idea what we're doing, but we really want to learn to take care of our pool ourselves.
    P.S. We know that pvc is a better option to hoses but for this year we want to keep the hoses and just focus on learning the BBB method. Hopefully next year we'll do our research and try to switch to PVC.
    Any advice and sugestions will be greatly appreciated.
    Re: Hose clamps leaking
    I have seen flex PVC used with barbed fittings. If that’s what you have, then it’s not the right connection. Flex PVC is reinforced so that it can’t collapse.
    If you have actual hose, then warming the hose first with warm water or a hairdryer can help. Not too hot or the hose will get too soft.
    If the clamps are rusty, they should be replaced. Using two clamps can help.
    Support the site
    May 2015
    Wichita KS
    29
    I actually had to his happen before on a sump pump discharge line. I ended up finding a small hairline crack in the pvc causing the leak from over tightening the clamp. Ended up replacing the pvc. So you might check for that. For me, continuing to tighten the clamp just made the crack bigger.
    Coleman 18'x48' AGP
    Intex Krystal Clear Sand Filter Pump 2800GPH
    Intex SWG
    **Under Construction** :)
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Try 2 new clamps in opposite directions at each fitting.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Mar 2016
    Greenville, SC
    16
    Thanks for your replies! We tried warming up the hoses with warm water and pushing them in farther, than re-tightening the clamps and the fixed two of the leaks!! For the third we added another clamp and that fixed it!! Thank you so much!!
    Support the site
