Thread: Pool pump issues
    Jan 2016
    Liberal kansas
    12
    Pool pump issues
    Okay guys new pool owner here. I am having trouble priming my pump or something I guess.
    Problem when I turn pump onto high it sucks the pump basket dry?
    I turn off pump reprime by removing basket lid till its full then I turn pump on again. Guess what it sucks the basket dry.
    Skimmer basket is clean as well as pump basket. Running mostly 2" pluming but reduced down to 1 1/2" going into pool and Hayward auto chlorinater.
    I can't figure out why...it will not lose prime on low and every time I try and vacuum pool I lose prime.
    Pool as been up for 1 week today
    ABG 18K Gal w/vinyl liner, 24" sand filter w/1.5 hp 2 speed matrix pump/hayward inline chlorinator/ K-2206 tes kit/ build date 3/22/16
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: Pool pump issues
    Low water level or a sticking skimmer flap (weir) are the most common culprits.
