Results 1 to 7 of 7
Thread: Crack in sidewall of 2 y.o fiberglass pool.
    I just noticed a 2 inch crack in the sidewall of our 2 y.o pool! I haven't contacted the installer yet because it's after business hours, but I wanted to get any advice you all have. I assume he'll suggest epoxy to get a quick fix, but I don't like that idea. The pool is manufactured by Leisure Pools, so theoretically it has a lifetime warranty. However, the installer didn't follow their guidelines during installation, so they're probably not going to honor the warranty. He didn't use gravel to line and backfill, and he didn't install a standpipe to drain under pool. When I confronted him after getting the warranty conditions, (after pool was in ground) he said that I'd never have to worry about it. I'm worried now
    15,000 gal fiberglass pool and spa, SWG, Pentair variable speed pump, Easy Touch controls, Aqua Cal heat pump.
    15,000 gal + Spa 500 gal, Fiberglass, SWG, Pentair variable speed pump, Pentair Easy Touch, Aqua Cal heat pump
    Jun 2014
    15,027
    Re: Crack in sidewall of 2 y.o fiberglass pool.
    Ugh. Not good news at all. But stick with it. Between Leisure Pools and your installer, they may have a plan that will meet your satisfaction. I certainly hope so.
    Update for those following. Our pool is fixed. Leisure Pools didn't ask any questions. They have a fiberglass repairman who travels all over, and he happened to be in SC this past week. He did a great job, and he said that he thought the fiberglass shell probably had a hidden defect from manufacturing or it got bumped during transit. Fingers crossed that we won't have anymore issues!
    Jun 2014
    15,027
    That's great. We'll give a thumbs-up to Leisure Pools on this one.
    Jan 2012
    'burbs of Augusta, Georgia
    7,279
    Can you describe how your pool was fixed?
    What was the procedure?
    Did they have to drain the entire pool?
    Do you have a well point??
    Quote Originally Posted by YippeeSkippy View Post
    I wasn't home, but the guy sent me pictures. They had to take about 2/3 of water out. They pumped it into a bladder, but the bladder burst! He ground the fiberglass down at the crack then re-glassed it and applied new gel coat. It looks like new. Now I just have to get my pool water chemistry fixed with the addition of all the new H2O! I don't know what a well point is?
    Apr 2016
    Kershaw, South Carolina
    80
    YAY... glad you got it taken care of.. I too have a fiberglass pool here in SC..
    Pool... IG 16,500 gal fiberglass, Pentair Sand Dollar filter, Pentair Superflow 1 speed pump, Pentair control box, Installed 4/2015, Test strips! HA! ;-), SWG, hot tub (spa) freestanding on deck, fill it from my well, sometimes through my water softener. Oh, and a HydroNet radio control leaf skimmer boat! AND... A brand spankin new Dolphin M500 robot! ;-)
