Results 1 to 17 of 17
Thread: Help with finding a cleaning cap
    Hello
    I would like a cell cleaning cap for my Salt generator. It is made by Aqua Comfort Technologies. If anyone can point me to a website I would greatly appreciate it. Aqua comforts website does not sell parts directly I believe.
    Thanks
    Tom
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Help with finding a cleaning cap
    Tom, what I always use is an expandable rubber plug in the bottom of the unit (we use Goldline generators and, though they make an acid wash stand/ fitting, it's just cheaper to use the rubber plug) 8)
    Luv& Luk
    -Ted
    Thanks for the reply. It seems to be like a 4" opening, would a rubber plug still be an option?
    Thanks
    Tom
    Mar 2007
    4,160
    The expandable rubber plugs I'm talking about come in almost any size to fit whatever pipe you're dealing with As long as you can seal the bottom of the cell, you're good 8)
    Luv& Luk
    -Ted
    K Thanks, I'll give it a try. I guess this is something I'll need to do like once a year or so? This is my first full season with the salt generator. We got the pool up and going last July and was very happy we did the salt. Set it and forget it!
    Tom
    Mar 2007
    4,160
    Gotta say "NO" to once a year. the acid will eat the coating on the blades of the cell. Check the cell for scale deposit a couple of times each summer and use the acid if you have deposits that won't wash off with a garden hose.
    These things aren't cheap and I want you to get the most life out of your unit 8)
    Luv& Luk
    -Ted
    Thanks for the info. It is possible I just need to add salt. I just opened the pool. I have an L shaped 18 by 40 with a another 8' coming off to make the L (by the steps). 3.5 at the low end and 8' at the deep end.
    We had a company come and vacuum it using their pump because of the amount of sand in it from the construction of the patio. For some reason they backwashed and added DE to the pool. I saw them adding it straight into the skimmer without mixing it in a bucket. After they left I went to start the pump but it was very caked with DE. I tried getting it going by just using the recirculate position but couldn't get a prime. On filter it worked but blew DE back into the pool. You want something done right you have to do it yourself! They never should have touched our equipment as I just got it setup 3 days prior.
    One question I have is how much would be the norm as far as adding salt each season? I will be picking up a salt test kit tomorrow
    Thanks again for the help
    Tom
    Mar 2007
    4,160
    Tom, I'm here for you and everyone else that has a question I feel qualified to answer 8) It actually helps me unwind to answer questions here after working on pools all day
    Have you read my 'Use and care for DE filters article? (here)
    If they had their own mobile vacuum rig, they certainly SHOULD NOT have been 'playing' with your system nor had any reason to add DE!
    Despite their shortcomings with what they've already screwed up, I hope you get to enjoy the pool soon 8)
    Once the salt is in and at a stable level, you'd only need to add more if you had to 'waste' :P or backwash often - draining and refilling the pool is the only way to lower the salinity.
    You didn't mention it, but I'll tell you anyway -- if you ever do need to add more salt, you'll also need to add stabilizer - salt and stabilizer (cya) won't leave the pool by evaporation, so if one of them gets low, it's VERY likely that you'll also have to add the other
    Luv& Luk
    -Ted
    Jul 2007
    Brisbane, Australia
    874
    Quote Originally Posted by waste
    That coating is acid resistant so it won't be eaten away. Unless you will leave the cell in acid for a few months.
    But i agree with you that it should be inspected/cleaned more often, depending on the level of scale buildup.
    Mar 2007
    4,160
    Strannik, how's everything 'down under'?
    Always a pleasure to share a post with you and I think we're on the 'same page' here I was trying to say that if there's no visible build up of calcium deposits, there's no need to break out the acid 8)
    Luv& Luk
    -Ted
    Jul 2007
    Brisbane, Australia
    874
    getting quiet
    our pool season has finished already
    i agree that it's unnecessary to clean if the cell is clean)
    Waste
    I read the DE post, very informative. My filter holds 7.5lbs of DE so I'll be backwashing and adding the 80% back into it tomorrow. Once I figure what 80% of 7.5 lbs is . Or 80% of 15 coffee cans........ I'll take that I'll be adding 12 coffee cans in when backwashing. Piece of cake
    Thanks again
    Tom
    I did a test of my salt water. It says to add about 6-7 40lb bags of salt. This will hopefully solve my problem of a low 65% salt reading on my AquaComfort generator. I'll do that before taking the cell apart
    Thanks
    Tom
    Another question... sorry
    I need to add 6 40lb bags of salt, how much stabilizer should be added? I'm told they go hand in hand
    Tom
    Just to update; I added the 240lbs of salt and my SWG reading is back at 100%
    Tom
    Mar 2007
    4,160
    Tom, it's always best to test the cya level before adding any ... but 2lbs cya per 100 lbs salt added should get you ~ 70 ppm, if the salt increases your level to ~3000 ppm salinity
    Glad it was as simple as adding more salt 8)
    Luv& Luk
    -Ted
    Thank you Ted
    I put 4 lbs of stabilizer and will runn the filter for 48 hours and re-check
    Thanks again ~ I like this site
    Tom
