Results 1 to 8 of 8
Thread: New Pool Deck - Now the Skimmers are Too Low
    Mar 2016
    San Antonio , TX
    5
    First post my friends. Great website. I added a new travertine tile pool deck and coping on top of my ugly old pebble deck. Looks awesome. However, the level of the coping went up 1-1/4" to 1-1/2". Then had to raise the pool tile and re-plaster. The travertine itself is not all that thick, but the with the thickness of the cement material used to put it down plus allowing from the correct sloping for drainage all contributed to everything being raised at the end of the day. Also had to raise the overflow drain to raise the water level on the tile.
    My issue is that we could not raise the skimmers according to the pool construction company as they are cemented in the gunite and have rebar over the top of them between the basket and pool edge. Well I suppose I could have them raised, but it sounds like a major messy project of hammering them out of the concrete, cutting rebar, raising the plumbing, concreting them back in, etc. and more dinero. So, consequently, the throat opening between the water level and top of the skimmers is reduced. Also, the skimmer basket is now too deep in the skimmer below the water level so the trash does not get pulled down into the basket, just floats on top. The easy solution is to keep the water level lower, but to do any good, I'll have to keep it just above the bottom of the 6" pool tile. Was wondering if I could put some small blocks or something about an 1" to 1-1/2" at the bottom of the skimmers for the skimmer baskets to sit on to raise them?
    Also worried about what will happen in the fall when the leaves drop. I'm afraid that they will just pile up in front of the skimmers and not move into the baskets. If anyone has any suggestions, would love to hear them.
    Thanks!
    38,364
    Re: New Pool Deck - Now the Skimmers are Too Low
    Welcome to TFP!!!
    I think the best solution would have been to not raise the time and just have a thicker coping (or an extra row of tile at the top) and just left the water level where it was. It is not easy to raise the skimmer. But, that is all in the past.
    You can not raise the basket, because then the debris could go around it and into the pump.
    Can you divert more suction to the skimmer?
    I still think you may need to just keep the water a little lower.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Welcome to TFP!
    That is a conundrum that I've never seen before. I do agree that to raise the skimmers would have been a huge amount of work.
    Jul 2015
    Central Valley CA
    1,109
    I have never used one but based on your description a skimm doctor might work
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Mar 2016
    San Antonio , TX
    5
    I believe that Skim Doctor just might be the ticket. Checked out their website. Pretty ingenious gadget. Thanks Atttech -2 for the tip!
    DFW, TX
    24,502
    Nice work atttech-2!
    Feb 2014
    Phoenix
    25
    I have been using the skim doctor for 2 years now and I love it. I see there is a .2 version now which make it easier to empty.
    1975, 18000 GL, Plaster never been re-plastered, 2 year Old Hayward Sand Filter, Very Old Pump made out of cast Iron, and Single Speed 1 HP motor. Mesa AZ
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,559
    And TFP is in for the win again! NICE job!
    Kim
