Thread: Preparing for summer
    Mar 2016
    Phoenix, AZ
    1
    Post Preparing for summer
    We bought a house two years ago which came equipped with a pebble tech 8,000 gallon salt water pool with a cartridge filter. This is the first pool I have owned and I have no idea what all needs to be done and when so I hired a service company to take care of it. Since then we have gone through a few pool attendants with the last one adding salt to my salt water pool a big no-no. I had a pool company test my pool water and they said my salt levels were way to high (9,000ppm) so I had to drain the pool and start over. Which brought me to this site.
    I want to learn how to take care of my own pool as then I will be reasonably assured it is done right.
    Bru
    Phoenix Arizona
    just another desert rat trying to cool off...
    My Pool - A salt water pebble tech. 8,000 gallons
    38,235
    Re: Preparing for summer
    Welcome to TFP!!!
    First, step ... Find TFP ... Done
    Second, step ... invest in one of the Recommended Test Kits and start learning
    Jun 2014
    14,959
    Bru, welcome to TFP! Best thing you could do for yourself at this point ... order a TF-100 test kit with speed stir. Mix like a pro with all the "accurate" results at home. Do NOT place your faith in others to test your water, not even the pool store. Most often they are off-target with their results and simply want to sell you expensive products. With your own tests, you can do it all. Great to have you with us.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Welcome!!
    Firing the pool service was a wise decision. No one will care as much about your pool as you will.
    A test kit is imperative. And not a cheap one from the pool store. I wouldn't even waste my time looking for a FAS-DPD test kit at a store. They're very scarce, and a pool store salesman will probably convince you the DPD test kit is the same thing, which it isn't.
    If you don't have 'em yourself, you'll need a pole, a brush, a net, and a vacuum and a hose. Unless there's an automatic cleaner of some sort which you failed to list.
    That equipment and Pool School and us will lead you to a sparkling pool all season long and much cheaper and easier than you imagined. Within a month during the swim season, I expect you'll be able to guess precisely what the pH, TA, and FC will read and how much acid it will take to adjust things so that testing is just a confirmation.
    Casey's Avatar
    SW PA
    10,418
    Welcome to TFP! Pool School has a wealth of information and how to's if n when you need to implement them. Ask questions when you can't find answers! We're always open!
