Thread: Re: Black staining of my beautiful pool. HELP!!!!!!!!!!!!!!!
    Mar 2016
    PLANO
    1
    Hi Swagger! I know Your post is 8 years old (!) but I'm curious to know if you solved your problem - and how; it is identical to the symptoms I have with copper staining after a commercial grade shock treatment was thrown directly in the pool. Please let me know! My plan is to buy CuLater to remove the copper in the water and prevent future stains, and then buy ascirbic acid powder to remove the existing stains.
    Mod note: Moved from this thread Black staining of my beautiful pool. HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    I don't have any experience removing copper stains. I think the first step is to eliminate the source of copper.
    These links might be helpful
    Pool School - Metals in the Water and Metal Stains
    Copper stain removal off plaster
