Thread: Testing bonding?
    Feb 2012
    Maryland
    400
    Testing bonding?
    While installing a deck on one end of my pool, digging for the post footers I found the bond wire. I hit it with the shovel but there was no distinguishable mark on it afterwards. Is there anyway for me to test the bonding is working? I thought I read someplace to take a multimeter and hook one end to the ladder, the other end to the pump bond lug. Does that sound right and if so what would should I expect to see on the MM?
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    38,521
    Re: Testing bonding?
    There should ideally be no voltage difference between anything (water, ladder, pump, etc).
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Shouldn't there be continuity between everything that is bonded?.
    chiefwej
