Results 1 to 7 of 7
Thread: First time slamming new pool
    Mar 2016
    Wimberley, TX
    51
    So new pool (not new pool owner) I just started slamming our pool that was completed back in August. I had started another thread some time ago about our rising PH and was able to get it into check by getting our TA down to 70. After getting the water balanced our CC jumped up to 1.5 and it was time to slam.
    Two days ago I tested our pool
    FC 1
    CC 1.5
    CYA 40
    PH 7.4
    TA 70
    I added enough bleach to get the FC up to 16 and have been holding it between 16-18 since then, needing to add a good amount of bleach the first few hours to keep the numbers in check. Bleach consumption has slowed down and the water is crystal clear. Pool has been vacuumed and brushed throughout the process.
    However I am getting a strong ammonia smell from where the spa spills over into the pool. Assuming this is gas off of CC, but not sure since I have never experienced this before. My plan was if FC levels continued to hold I would shut the pump down at sunset tonight and do an overnight test.
    Any thoughts regarding this smell and if I should be doing something different with my slam procedure because of it?
    15K Gallon, IG Pebble Sheen pool with SPA (8/15/2015). Wrap around stone waterfall, spill over spa and bubbler on tanning shelf. Pentair FNS Plus 60 DE filter, Pentair Whisper Flo for filter circulation and Pentair Intelliflo for water features. Pressure side pentair sweeper, Pentair heater and Rainbow 320 Chlorinator (just use to keep CYA in check), Haas Liquidator and all powered by a Pentair Intellitouch system. K-2006 test kit.
    Jun 2014
    15,221
    Re: First time slamming new pool
    I suspect you are correct about the smell. At the same time though, the test results you posted are a couple days old. How is the FC and CC numbers today? If the CC is under .5, and your FC is holding, sure - do an OCLT this evening. But leave the pump running. You still want that circulation to continue until you know for sure the SLAM has passed all 3 SLAM criteria. Be patient. If you've only been SLAMming for 2 days, your pool may need a couple more. 2-3 days is an exceptionally fast SLAM. Hang in there and maintain. Sounds like you are doing fine.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    looks like your doing good agree with Pat, post up some new numbers and let it roll a couple days and see what happens
    Mar 2016
    Wimberley, TX
    51
    I've been checking the FC every few hours since starting and have kept it in the 16-18 range.
    The current reading this AM shows FC of 18 and CC of .5
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Should leave the pump on 24/7 when performing the SLAM procedure, including during the OCLT. What was your FC reading last night?
    Isolated Spa - 345 Gallons
    Mar 2016
    Wimberley, TX
    51
    I checked FC at 9:00 last night and it was 19. Last does of CL was at 5:00pm yesterday when it dropped to 14.
    I will say before I started the SLAM my water was clear, but there obviously was some nasty stuff living in it from my test readings.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    I have definitely had algae and clear water before. Be sure to brush regularly. Daily-ish during the SLAM and weekly-ish otherwise.
