Results 1 to 7 of 7
Thread: Vacuuming pool
    Aug 2015
    CRESTVIEW, FL
    3
    Vacuuming pool
    Hi, I hope this is posted in the correct area. I have an Intex 15' X 4' above ground pool with a SF20110 sand filter. I also have a skimmer basket attached to the pool. While filtering the water I have excellent suction but when I attempt to vacuum the pool I lose all suction. What am I doing wrong or what can I do to fix the problem?
    Jun 2014
    15,153
    Re: Vacuuming pool
    Hello and welcome to TFP! Is it possible that the hose you are using is full of air? We usually fill the vacuum hose full of water before attempting to vacuum with it to ensure the pump doesn't lose its "prime". Me personally, I hold the hose underwater at a return jet to fill it up before connecting the other end to the skimmer. Can you confirm that for us please? Nice to have you join us.
    Aug 2015
    CRESTVIEW, FL
    3
    Re: Vacuuming pool
    Thank you for the welcome and that tip. I usually just try to hold the hose (which is naturally buoyant) underwater to fill it with water. However, I have to take the skimmer end out of water to connect it to the skimmer. It definitely loses it's prime and nothing that I do makes it regain it short of removing the hose. I am glad to be a part of group!
    Intex 15' X 4' above ground pool with an Intex SF20110 sand filter.
    Jun 2014
    15,153
    Re: Vacuuming pool
    I hope that trick helps. If you continue to have problems, let us know and we'll see if there's a Plan B.
    Aug 2015
    CRESTVIEW, FL
    3
    Re: Vacuuming pool
    That tip did the trick!!!! I have finally been able to get the bottom of the pool clean. THANK YOU!!!!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    Re: Vacuuming pool
    SWEET! What a nice feeling to see it sucking up all of the stuff on the bottom! TFP scores again!
    Kim
    Casey's Avatar
    SW PA
    10,446
    Re: Vacuuming pool
    That hose definitely needs to have as little air as possible.
