Results 1 to 9 of 9
Thread: LED Light advise
    Mar 2016
    Chicago,IL
    88
    LED Light advise
    http://www.americansale.com/Products...e-455f32183acd
    I ordered this light to have installed in my new pool.
    Any good or bad info that anyone can tell me about it???
    19k 15x36' inground oval vinyl lined pool with deep end. 3 returns , 1 skimmer, 1 main drain. TF-100 test kit
    38,475
    Re: LED Light advise
    Awfully small and the light output looks weak. Having a couple of them around the pool might work ok.
    Casey's Avatar
    SW PA
    10,453
    That light hooks into the return of an above ground pool so it's one unit.
    38,475
    I am sure that is not approved for use around a pool.
    Apr 2013
    Sacramento, CA
    2,769
    Its designed for pools, its UL listed and it should be plugged into a GFCI protected plug. Is it safe? Well those are the same requirements for most lights in any pool.
    38,475
    Quote Originally Posted by gwegan View Post
    Are we looking at the same thing? Are you talking about the solar powered rope light? Because I see nothing about UL approval, designed for pools, ability to plug into GFCI socket, etc.
    Mar 2016
    Marrietta Ga
    82
    I bought 2 of these for my pool..I am sure they could be brighter but I am pleased..They have a few different programs that change colors which is pretty cool..They are new so not sure how they will last.
    Amazon.com : 252 LED 120 Volt Color Changing Replacement Swimming Pool Light Bulb : Swimming Pool Lighting Products : Patio, Lawn Garden
    Casey's Avatar
    SW PA
    10,453
    Quote Originally Posted by markayash View Post
    What kind of pool do you have Markayash? Please add a signature. Thanks!
