Page 1 of 2 12 LastLast
Results 1 to 20 of 37
Thread: Clear water but dropping FC
    Feb 2015
    The Woodlands TX
    46
    Hello everyone!
    My situation is pretty much the way the title sounds. Last week, after a winter of only occasional attention, I noticed my pool had some slight green along the walls and floor. I ran the numbers, and they came out looking like this...
    FC - 0
    CC - 0
    pH - 7.8
    TA - 70
    CYA - 30
    I poured 121 oz Clorox 8.25% in the pool, and brushed the sides and bottom. I also vacuumed. Each of the next 3 days I added one bottle of Clorox. The FC would come in around 10 to 12, CC at 0.5. Within a day or so, the pool became clear, and the green disappeared. All good so far.
    I ran the OCLT each of the last two evenings, and I am losing about 1.5 each time. Specifically, last night my reading was 10.0, CC 0.5. This morning I was at 8.5 and 0.5. This afternoon, I tested and got FC 6.0 and CC 0.5. The pool still looks clear with no green accumulation. I also backwashed the filter this morning.
    Should the high chlorine drop in the OCLT concern me? Everything looks good, and the numbers are close, but not perfect. What do you think?
    12,000, IG 1992, 4.5' center/3' each end, Pentair FNS-60 DE Filter (2015)
    PebbleSheen installed 2015
    Pentair Superflo VS installed May 2016
    TF-100 Test Kit
    Dolphin Nautilus Plus Robot
    Jun 2014
    15,008
    Re: Clear water but dropping FC
    Red, don't let the clear water fool you. It looks to me as though you simply need to employ a "SLAM" and knock that algae out for good. Simply adding one gallon of bleach each day won't do it. You'll need to "maintain" the required SLAM FC level until you pass all 3 SLAM criteria. With a CYA of 30, your SLAM/Shock FC level should be maintained at "12" - 24 hrs per day until the SLAM is complete. If everything is done as noted on the SLAM page (link below in my sig) you should do just fine. Let us know if you have any more questions.
    Oh - don't forget to lower the pH to 7.2 - 7.5 before raising the FC to 12 for the SLAM.
    Feb 2015
    The Woodlands TX
    46
    I was afraid that was where this was heading. I appreciate the advice, and will update on my progress.
    TF-100 Test Kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    I have had algae and clear water. Good luck with your SLAM!
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    My pool is also 12,000 gallons and if my FC were zero, one gallon of 8.25% liquid chlorine would only bring it up to about 7.5 of FC.
    18 ounces=1ppm FC in my pool.
    You never had your FC high enough to actually kill all the algae. Please review the SLAM directions.
    Let us know how it goes
    Aug 2014
    Northern IL
    4,615
    Don't be afraid of a "slam". This may be the last time you have to do it in eons.
    Feb 2015
    The Woodlands TX
    46
    I probably used the wrong term in saying "afraid". After 8 months of reading this forum, and doing my own chemistry and maintenance, there is literally nothing about this pool that scares me...thanks to everyone here.
    OK, so last night I added 60 ounces of muriatic acid to reduce the pH in preparation for the SLAM this morning. This morning, my numbers looked like this...
    FC - 14
    CC - 0.5
    pH - 7.2
    CYA - 22
    I was a little surprised that my CYA had dropped further, but we did get a lot of rain last week. Should I do anything about the CYA now during the SLAM? Should I do anything to raise it once my SLAM is complete? Everything else looks to be pretty good.
    Quote Originally Posted by YippeeSkippy View Post
    You are correct. The first gallon took it to 7-7.5. The next day, an additional gallon took it from 5.5 to 12. Last night, I added one gallon to the existing 6.0 level, and this morning I am at 14. So, the numbers seem pretty consistent with what you predicted.
    TF-100 Test Kit
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I would get enough CYA in the pool to get it to 30, but only just enough. It could be a testing error as the CYA test is a bit subjective and can vary based on the lighting when the test is performed. Consider retesting before adding CYA. Once you complete the SLAM, I'd certainly get the CYA up to 40 or 50 based on your location. Rain won't drop your CYA by that much either. If the test was accurate, you lost 8 ppm CYA. In order to accomplish that, you'd have to replace 25% of your water.
    Isolated Spa - 345 Gallons
    DFW, TX
    24,450
    Quote Originally Posted by RedScare View Post
    Good answer!
    I would leave CYA where it is for now.
    Feb 2015
    The Woodlands TX
    46
    I believe I have some trichlor tablets left over from my auto chlorinator days. Would you recommend running that for a few days after the SLAM is complete to boost CYA? Or, is their some other method that works better?
    TF-100 Test Kit
    Feb 2014
    Central Minnesota
    5,080
    When increasing CYA, it's best to use just pure CYA. Check out Pool School - Recommended Pool Chemicals and the details on CYA and how to add it to your pool.
    Save the pucks for when you go out of town for a few days and have wiggle room with your CYA. Pure CYA can be bought at many big box stores that have a pool section. HTH is my favorite brand so far as it has finer granules that dissolve faster.
    DFW, TX
    24,450
    Using up old trichlor is fine for adding CYA. The pucks are acidic so keep an eye on your PH. Once you run out of pucks just add CYA/stabilizer. I get mine in 4lb bottles from Lowes.
    Here is a handy page on pool chemicals, what they are, what they do and how to add them.
    Feb 2015
    The Woodlands TX
    46
    Great. Thanks!
    TF-100 Test Kit
    DFW, TX
    24,450
    Hey, don't listen to that other guy posting at the same time as I do! He says weird stuff!
    Feb 2014
    Central Minnesota
    5,080
    Haha!
    My response was first both times so it must be right!
    Truth is... we're both right!
    Feb 2015
    The Woodlands TX
    46
    I suggest a cage match to determine who is correct.
    TF-100 Test Kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    You are getting great advice, but I have a question. What are you using to measure CYA of "22"?
    Support the site
    Feb 2015
    The Woodlands TX
    46
    I'm using the tube in the TF100 kit. The level did not quite reach the 20 mark. I estimated it to be at a 22 if the tube had markings that precise.
    I did not get a chance to test yesterday evening. My last test was at 3:30 pm, with an FC level of 12. This morning, FC came in at 11. I will do an OCLT this evening to see how it looks.
    TF-100 Test Kit
    May 2014
    Franklin, NC
    9,184
    You can't make assumptions like that. The scale on the tube is not linear so you can't say that half way between 20 & 30 is 25. Always round up for FC/CYA calculations, so in your case SLAM for a CYA of 30.
    Support the site
  20. Back To Top    #20
    Feb 2015
    The Woodlands TX
    46
    I see. Speaking of chemistry interpretations, when testing the chlorine level, I have noticed that after letting the water sit for several minutes the previously clear water returns to a shade of pink. Is this a normal reaction? The water had been clear at the time of testing. It is only after sitting for at least a couple of minutes that the solution turned pink again.
    BTW, this evening's test came in at 11. So, only a drop of 1 ppm all day, after a drop of 1 ppm overnight. This looks very encouraging. Water is still clear.
    TF-100 Test Kit
