Thread: PoolMath problem
    PoolMath problem
    Is anyone else having a problem with the PoolMath calculator or is it just me? I can't seem to get it to tell me how much muriatic acid to add to raise pH; the number just stays at 0. The washing soda and borax areas will update just fine, but the acid sections stay at 0. It's always worked fine in the past...
    Jun 2014
    15,070
    Re: PoolMath problem
    The Poolmath calculator seems to be working fine for me. I just tried it. Are you using the same link I showed? Some folks get side-tracked with an old calculator link that has since been closed.
    Oh, and of course .....acid is used to "lower" pH. That may be why you don't see a number on the Baume row.
    Haha... yeah, just a typo; I meant lower pH... this is just weird. I went to the calculator on my phone's browser and it worked as expected. I will try on my work computer tomorrow; maybe it's some weird glitch with my home laptop? In the meantime I can use my phone! Thanks so much for your quick reply!
