Thread: Anyone try this stuff?
    coastal's Avatar
    Apr 2009
    Stuck In Paradise
    I have a cartridge filter. It's works good, easy and inexpensive to maintain but it's just not quite as clear as the DE filter I had on previous pool.
    I saw stuff called "Fiber Clean" at the pool store and the idea is you put this in the filter via the skimmer and it's supposed to filter out smaller particals, viola, cleaner pool.
    Anyone use
    30x18 inground plaster/pebble with spa
    Hayward cartridge filter C751 1.5 hp pump
    In line tablet chlorinator
    Heat pump heater
    Aqua Logic wireless controls
    Re: Anyone try this stuff?
    It's a cellulose based DE substitute. It will help filter out smaller particles, especially if your cart is older but might require more frequent cleanings of the cart since what you ar doing is intentionally "dirtying" the cart so it filters smaller particles.
