3) Upgrade Filter: Based on forum input I am considering putting this off another year. I am definitely going to re-plumb my equipment pad (which is slowly sliding into the creek) -- the main reason I thought it timely for a new filter. Does anyone like Pentair's Quad DE?. I've noticed that the Texas input thus far (including from my initial pool guy) favors big sand filters over big DE or cartridge filters.
I don't know about you "nutty Texans" but this crazy Arizonan LOES his QuadDE-100 filter
My pool is only 16,000 gallons and I have a QuadDE-100 so it's definitely oversized relative to the pool volume BUT I also have a 3HP IntelliFlo, so it's not oversized relative to that. One thing I love about the filter is that, because it's oversized, I backwash it maybe, maybe, 4 times per year total. I also tear it down once per year. Even so, I could go longer stretches between backwashes as my system pressure starts off around 10psi and almost never goes higher than 13psi even after long stretches between backwashes. I still get spectacular flow rates out of the returns even when at the higher (dirtier) pressures.
I like the Quad design because it's basically Pentair's Clean and Clear cartridge filter system except they put in different cartridges to handle the DE. So, when tearing down, it is very easy to remove the cartridges and clean them. Unlike a gird style filter where you have lots of grids to clean, the four cartridges, I feel, are easier to get out and put back on the manifold. The nice part is if I decided in the future I did not want to mess with DE anymore, you can technically convert it back to a Clean & Clear cartridge filter just by installing different cartridges (though Pentair will not admit it...).
My only gripe is that I think Pentair could have done a much better job designing the internal structure of the filter body to create more turbulent flow and thus utilize the DE better. As it is designed right now, A LOT of DE just settles into a thick mud on the bottom of the filter and rarely gets stirred up. I don't follow their recommendation of using a full charge (10lbs) with every backwash because that is just ridiculous. You barely remove 50% of the DE with a backwash so I only add back 4-lbs or so with each recharge and so I don't have a lot of DE consumption. I think I'm on my second 25 lb box of DE and it's been a few years now.
Water clarity is always crystal clear and, at night, I barely see any of the "floaties" you normally see in pools with lower filtration sizes (sand and cartridge).
So, as long as you don't mind messing with DE and if you have the budget for it, I'm 100% sure you'll love the results you get from a QuadDE filter.
My opinion, FWIW....
Best of luck to you,
Matt
PS - Oh, and just stick with the standard push/pull plunger valve for backwashing. Pentair sells a multiport valve manifold for the QuadDE systems but those multiports have terrible head loss associated with them and can really restrict your system flow.
