Thread: heat pump installation
    mcmeekin's Avatar
    We're nearing the end of a pool install. The heat pump was placed today and is a Jandy. I'm used to a gas heater and the one at our old pool needed and had a 'fireman's switch' for the timer to shut off the heater 20 minutes before the pump to allow a cooldown of the heater.
    This heatpump book says nothing about such a switch. Do heat pumps not need the same cooldown process?
    upstate SC , 11K gal IG vinyl liner, 1HP superflo, Pentair DE filter, AE-Ti Heatpump, Aquarite SWG, Colorsplash LED,2 Bubblers, 4 Deck jets, Small interfab slide (3.5'), Coverstar opaque blue automatic cover.
    install completed 7/5/2007
    The heatpump has a built in flow or pressure switch and will stop when it senses no or low flow.
    20x40 IG vinyl, heatpump and solar and 3 siberian huskies, 10kw PV solar electric system. Nikon Photographer D800e dSLR.
