Results 1 to 18 of 18
Thread: Question about unread posts
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    Is there a way to have posts with unread posts come to the top each time? I gone thru every menu and can't find an option for it.
    14.3k, 3 1/2-5 1/2, IG, Pebble Wet Edge Northshore Tahoe, Jandy 4 cartridge, Jandy 2hp variable, Pentair 320 inline chlorinator fed by a Stenner, Polaris 280, K-2006 test kit, Built 9/13
    Fill water: TA=90, PH=70, CH=90
    38,524
    Re: Question about unread posts
    You want to click the "new posts" link, I think
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    As you've opened a list of posts, and are done reading/responding, you want to go up to <Forum Actions> and click <Mark Forums Read>. Then the next time you want to read posts you just need to click <New Posts>.
    38,524
    No need to mark the forums as read. If you do that the older posts, that you have not read, will not show up under "New Posts" either.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Top left, right under "Home". Also, if you look under "Settings", it will show anything with new posts under threads in which you've started, responded, or subscribed to. You can get notifications for threads without posting by going to "Thread tools", then pick "subscribe to thread" while in the thread you want to keep track of. Hope that helps!
    Jan 2012
    7,373
    If I am not interested in the original post, I don't need to see it again. Hence when I'm done going through all the posts, I mark them all read. Then the next time I open up and hit <new posts> I'm seeing only stuff that's new, or posts with new responses (which may still be uninteresting to me, but I see it). It lists all the new posts in a list, not by subforums. It works well for me. YMMV
    I also like to review the posts I've answered and subscribed to by using the <subscribed threads> option under <search links>
    38,524
    If you want to get fancy, I made a custom search that shows my participated threads (this is like the view you get in Tapatalk).
    Go to "Advanced Search", choose the "Search Single Content Type" tab.
    Set "Search Type" = Posts
    Enter your username and select "Find Latest Posts by User"
    Search All Open Forums
    Find Threads: "At Least" and blank
    Find Posts: "Any Date" "and Newer"
    Sort Results by: "Last Posting Date" "in Descending Order"
    Show Results as: "Threads"
    Then hit "Go" by the "Save Search Preferences"
    Every time you go back to that search page, the setting will be saved like this.
    So 3 clicks and I have a list of all the threads I have participated in, with most recent modification at the top. And they are BOLD if you have not read them since the last post.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    That same thing happens in my "Settings" on the desktop mode.
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    Thanks
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    we need a button like new posts I know it will show in new posts
    No response/reply button...
    someone with no reply's can get lost very fast, and I would love to hit a button and see "first posts"
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,656
    Casey, Look up at the darker line up top...........Find "My search links", there is one in there that says "Unanswered post week".
    The one I use is "Today's posts".... it shows what has been posted since I last signed on BUT one thing I have to watch is there will be some new posts happen while I am on TFP working on threads so I might miss them so I always go back below the "New since you signed on last" line to see if missed any just below the line.
    Kim
    Jul 2013
    Fletcher, OK
    3,353
    That would be awesome Kim, but it is not on mine..
    I have 4 links
    my threads
    my posts
    todays posts
    my subscriptions
    Maybe an admin feature?
    Chris19D's Avatar
    Jul 2015
    Cypress, Texas
    89
    Is there a way to add the feature to 'like' or 'appreciate' specific posts?
    It could come in handy and keep threads better on topic if someone was able to appreciate a post instead of replying and potentially moving it off topic. I've seen it work successfully in other forums I follow.
    LOL, did I just go offtopic myself? Dangit!
    ~Chris - 20,000 gallons free-form gunite / Pebbletec, Aquapure 1400 SWG, 2 HP Jandy VS Main Pool Pump, 2 HP Jandy Water feature Pump, 580 Jandy cartridge filter, Dolphin M500, TF-100 w/Speedstir.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Quote Originally Posted by cowboycasey View Post
    I have 4 links
    my threads
    my posts
    todays posts
    my subscriptions
    Yes, guides, experts and mods have it.
    I mostly use the new posts link, same as Yippee. Scan all the new posts and mark them read. Repeat. That way I see all posts in all forums in one place.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I often use the more visible "What's New" tab-type button on the top. Going to have to start using the New Posts instead!
    Isolated Spa - 345 Gallons
    DFW, TX
    24,514
    Using New Posts is handy on several levels. It has a green arrow on threads you have replied to so you can see those at a blance. It also has a last unread post button that will take you right to the last post that you haven't read, so no scrolling to figure out where you last read. That is the coolest! It is the little button next to the thread title. Click it!
    Jul 2012
    Tallahassee, FL
    30,656
    I have 4 links
    my threads
    my posts
    todays posts
    my subscriptions
    psssstttt Casey see the red? that is the one I was talking about. See if that works for you.
    Kim
    Jul 2013
    Fletcher, OK
    3,353
    LOL it does Thanks
