Thread: Just ordered aqua finesse water care tablets...hope this helps with the slime/mold
    Jul 2014
    Berks County, PA
    206
    I think this is the last ditch effort to be able to continue with baquacil and hopefully control the pink slime and white water mold issues. I've read good things about these aqua finesse tablets. From the research, it does appear that biofilm issues are not only associated with baquacil, but yet from what everyone says here it seems much more common a problem with baq as opposed to chlorine. I'll report how things go once I get underway in a few weeks.
    12,000 gal. Anthony IG pool; 3 ft. shallow end to 6 ft. deep end; Built 1989; Renovated July 2014 using a 10-part unexposed quartz plaster aggregate of 3 S-grade Blue, 3 S-grade Gray, 2 T-grade Blue, 2 T-grade Gray; Apollo VA-52 DE Filter; Hayward SP-2607X10 Super Pump 1-HP Single Speed; Jandy AE-Ti Heat Pump; Taylor K-2006 Test Kit
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Just ordered aqua finesse water care tablets...hope this helps with the slime/mol
    Good luck, I have been there with fighting Baqua Slime, and will never go that route again.
    30,421
    From the traffic we see here on the forum, baquacil appears close to dead. I'm sure there are those that are having no issues but we don't hear from them.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    I've never used it and never will.
    It always is the same story...works very well for a 2 maybe 3 years then problems arise.
    Dolphin E10 Cleaning Robot.
    Donldson's Avatar
    NW Ohio
    2,898
    Sodium Carbonate and Disodium Metasilicate. Both very basic so keep an eye on your pH. Good luck.
    Even the dealers I know have stopped carrying baqua products. Despite the decent profit to be made from it, when things go wrong and the customers switch back to chlorine they tend to find another dealer too.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
