Thread: Automatic Multiport Valve and Variable Speed Pump
    Mar 2016
    Spain
    3
    Hi,
    I am new to pools and have a question regarding Automatic Multiport Valves and a Variable Speed Pump.
    If I have a valve such as this:
    http://pdbdocs.astralpool.com/manual...02_2011-01.pdf
    And a pump such as this:
    Viron P320 eVo Pump | AstralPool
    How do I make sure that the pump automatically switches to high power when the valve performs a backwash?
    My pump will run 24 hours a day on low, and I assume it will need a higher flow rate to do a thorough backwashing.
    Do I need some sort of controller device, or can the valve communicate directly with the pump?
    Thanks very much.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: Automatic Multiport Valve and Variable Speed Pump
    Welcome to TFP!
    I've never seen an automated backwash valve before. Most folks manually backwash their sand filters when the pressure rises 25% from clean pressure. The VS pump has a timer and can be set to run at different speeds at specified times. The timer in the pump should be able to be set to to run at higher speed to coordinate with the backwash time.
    30,414
    Yeah, I've never seen that either. I believe you will have to go to your PB or the Manufacturer for guidance.
    Mar 2016
    Spain
    3
    Thank you both for your help.
    From what I understand, the valve can be set on a timer and also set to measure the pressure and perform a backwash when it reaches a certain level. As pooldv mentions, a 25% rise is adequate.
    I will certainly get in touch with the manufacturer to ask the details.
    Thanks again.
