Results 1 to 10 of 10
Thread: Electric shock in pool
    Mar 2016
    North Central Arkansas
    2
    We bought a house with an inground pool that has a vinyl liner and no drain in the pool. We are sometimes getting small shocks, usually when touching the concrete when getting out of the pool.
    We have done a bit of trouble-shooting and our electrician and the local energy company both think the pool was not grounded.
    Is there anything we can do?
    Thank you!
    Re: Electric shock in pool
    You should have an electrician with pool experience to check everything including the bonding.
    Support the site
    Jun 2015
    Charlotte, NC.
    82
    Definitely sounds like a bonding issue. Make sure the electricians you talk to understand bonding and pools. It is NOT the same as grounding.
    - Matrioux
    2007 18K pebble IG pool - Wincor Pool Systems automation & SWG (under development) - DE Jandy DEL60 Filter - Jandy 1HP Pump - TF-100 Test Kit
    Mar 2016
    2
    Thanks for the replies regarding the bonding. I'll start reading up on it and look for an electrician who is experienced in this area. Do you think it's something that can be fixed without (worst case scenario) digging up the pool? That is my worst fear!
    JenniferF
    In-ground Pool
    Vinyl Liner
    3 feet to 10 feet deep
    Casey's Avatar
    SW PA
    10,444
    I'm unsure of what actually needs done to fix the situation but I urge you to not allow anyone in the pool until it's fixed.
    Jun 2015
    Raleigh
    357
    Most inground pools will have a metal form/skin around the vertical walls behind the liner. These walls must be bonded together as well as any metal stairs, pumps, lights, fences, etc within 5 feet of pool. Get an experienced pool installer involved.
    18' x 38' Pool, 3' to 8' Depth
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    Jan 2014
    Buckeye AZ
    807
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Jun 2015
    Charlotte, NC.
    82
    Doubt that was the same thing, but proper bonding MIGHT have helped/stopped the issue, though that's not what bonding is really for. At least thats my read on what happened; I think there was a much larger electrical issue with that pool than bonding.
    - Matrioux
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    ya more than likely poor grounding / lack of gfci protection on powered components
    Dolphin E10 Cleaning Robot.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,505
    I would like to add this:
    PLEASE make sure everyone in every family knows how to throw the breaker for the pool for just in case of many problems. Have them do it so they know what it takes to push it all the way over.
    Kim
