Thread: What about Bonding an above ground pools?
    Mar 2016
    Avon, NC
    1
    hi linen - i have been researching and searching for answers to my particular situation and have not yet found a logical or conclusive answer on bonding - perhaps you can provide some logic: I have an 11x22' all fiberglass pool (designed to go inground) - being installed here in the outer banks, nc, however this pool is elevated up to the first floor level about 15' in the air on 28 pilings. Therefore, it is an above ground pool with absolutely no metal in its composition or accessories - (there is an underwater LED (12v) light. I will be bonding the pump housing, gas heater, 12v transformer housing and the water using a Perma-Cast PB2008 Water Bonding Fitting which will be located inline between the filter and pump. I see no logic in running any #8 wire to the pool as there is no apparent reason to do so - your thoughts on this? and do you also bond the sub power panel ? I don't see anything about that - thanks in advance / keith
    Jun 2012
    western NY
    1,560
    Re: What about Bonding an above ground pools?
    The sub panel does not need bonding. You did not say what material the deck will be made of. The light niche, if metal will require a bonding wire.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
