Thread: Replace Aqua Logic AQL-PS-8 SWG
    Mar 2016
    Carlsbad/California
    5
    I have an old (10 year) Aqua Logic AQL-PS-8 control system. I have repaired the SWG section of the main circuit board three times and I am starting to have trouble again, the current to the T-15 starts off at 6 amps and over time 50 min the current will drop to approx 3 amps. The T-15 cell is a little over 2 years old and very clean. The board and or components are either a bad design or bad implementation or both and I am getting tired of fixing it. The rest of the control system has worked fine for the 10 years. So I am going to replace the SWG system with either a Hayward Aquarite AQR-15 or a Pentair IC40 and controller and continue to use the AQL for the motor and misc controls. The AQR-15 is much easier to install but I am concerned if the AQR-15 controller has the same board problems as my old AQL-PS-8. If so I would then go with the Pentair SWG and controller.
    15k gallon in ground Gunite pool and Spa, installed 2006. Goldline Aqua Logic AQL-PS--8 controller with T15 SWG. 2-speed pump
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Replace Aqua Logic AQL-PS-8 SWG
    The Intellichlor is not without issues either: Intellichlor issues OR problem site:www.troublefreepool.com - Google Search
    I have an AquaLogic and it has performed very well for me.
    I suspect you are not repairing the main board properly which is why it keeps failing. The K1 relay may need replacing too. But you can also get a new board on eBay for a decent price.
    Hayward GLX PCB Main PCB Replacement Aqualogic Main Printed Circuit Board New | eBay
    Mark
    Mar 2016
    Carlsbad/California
    5
    I did replace the K1 relay about 3 years ago, and the board has been working fine till now. But your point may still be valid. Thanks for the advice, I wish I could find out what the failure rates are for Hayward and pentair units and the decision would be easy.
