Results 1 to 11 of 11
Thread: Both skimmer lines clogged with leaves. Drain king not working.
    May 2012
    Austin, TX
    140
    Can't get then unclogged. What's the next step?
    ~23,500 Gallon In-Ground Plaster Pool, Intelliflo VS+ Pump, Hayward 4820 DE Filter, IntelliChlor IC40 SWG
    38,271
    Re: Both skimmer lines clogged with leaves. Drain king not working.
    shop vac? air pressure? plumbing snake?
    The real question, how did your lines get clogged if you have skimmer baskets?
    May 2012
    Austin, TX
    140
    That's a good question. I had a lot of construction done on the pool...plus we have so many trees it's usually covered during the winter.
    May 2012
    Austin, TX
    140
    One of the skimmers is full of polymeric sand from the paver remodel. Nice.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    That's a bummer! I would probably go with a plumber's snake. Disconnect the pump if it is connected with unions or put a towel or something to catch the junk. If there are Jandy valves in front of the pump take the cover off first and try to grab stuff there.
    Dec 2014
    Houston, Texas
    134
    Here's a shot in the dark but it usually works for me. I call it popping (not trademarked yet). Get the VS pump going at full speed on the main drain open the skimmer line, wait for the pump to recover then slam shut the main drain valve. Count to 5 and re-open. Rinse and repeat. Hopefully that will get it. If not I suggest rigging up an air compressor to a threaded fitting for the skimmer and trying that, don't forget to open the pump lid.
    GL!
    carlos31820's Avatar
    Nov 2010
    Midland, Georgia
    353
    Another thing you could try is to use the drain king on one end while holding a tennis ball in the other end to build up pressure. Hold the tennis ball as the drain king runs until pressure builds up. You'll be able to tell when the pressure is really building up because you'll hardly be able to hold the tennis ball in place and the sound of the drain king will change. When it does, quickly release the tennis ball to let the pressure release immediately. Keep repeating until the blockage is removed. I had my skimmer line plugged with pine straw (skimmer basket was missing) and the drain king alone would not do a thing. Mostly because water would move thru the pine straw blockage and not really build up pressure. It took about 5 tries of the tennis ball trick to have a giant clump of pine straw come flying out.
    16x36 Vinyl Pool - 22.5K gallons.
    Jandy Stealth 1hp pump - Jandy CS-150 filter
    Jandy Legacy 250k heater - Jandy Ei SWCG
    Jandy Watercolors LED light
    Paramount Vanquish in-floor cleaner
    May 2012
    Austin, TX
    140
    One of the lines magically unclogged itself. The leaves blew into the motor and the valve that was unscrewed popped off. It was very dramatic.
    Now I just have to deal with the one line that is clogged with sand.
    DFW, TX
    24,483
    Good news! Halfway there!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,444
    The snake may be the best bet for the sand one......What a pain
    Kim
    May 2012
    Austin, TX
    140
    I broke one shop vac and got a nicccce shock. So I ordered and even bigger shop vac! Will keep you posted.
