Results 1 to 10 of 10
Thread: lakepool145
    Mar 2016
    milledgeville, GA
    4
    Question lakepool145
    Hi! We've recently installed a 30' x 45' in ground salt water pool with overflow spa and two 24" sheer descents. It's beautiful except for one of the 24" sheer descents. It doesn't flow correctly and dumps a lot of water in the surrounding area. Our pool builder says its because of the water pressure and we just need to live with it. I think it's something else. Can anyone give some advice?
    Thanks a bunch,
    Jun 2014
    15,269
    Re: lakepool145
    That kind of reply sounds like a contractor who already received their final payment. I hope they can do better than that for you. I don't have a specific remedy for your sheer decent, but did want to say welcome to TFP! Nice to have you with us.
    38,526
    Re: lakepool145
    Welcome to TFP!!!
    I agree, sounds like the builder giving the run around.
    Post up some pictures.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: lakepool145
    Welcome to TFP and congrats on the new pool!
    They should have installed a valve for each sheer descent so that you can adjust the water flow to it.
    Mar 2016
    milledgeville, GA
    4
    Re: lakepool145
    Thank you everyone!! No we haven't made the final payment and there are separate valves for each descent and at full pressure and being the only one running it doesn't flow right.
    Mar 2016
    milledgeville, GA
    4
    Re: lakepool145
    Thank you and final payment hasn't been made😊
    38,526
    Re: lakepool145
    Quote Originally Posted by lakepool145 View Post
    Well, I doubt it was designed to run that way
    Is there any problem when both are running?
    Mar 2016
    milledgeville, GA
    4
    Re: lakepool145
    Yes, actually it flows the same regardless if it is on by itself or running with the other shear, bubblers and spa all at one time. It also dumps a lot of water which the other one doesn't do. The shears are designed to arc over a fire feature and into the pool. At corrosive as salt is, I'm sure we will be replacing the fire feature in no time. I will post some pictures as soon as I figure out how. LOL and thanks for replying.
    DFW, TX
    24,514
    Re: lakepool145
    Upload pics to Photobucket, copy the IMG code on the right and paste it in your post.
    38,526
    Re: lakepool145
    To post more/larger pictures, you either need to raise your storage allotment by Becoming a TFP Supporter or follow the How To Post Pictures tutorial.
