Thread: Hayward versus Other; Single speed versus Variable speed--->Help Wanted
    Tiger Lily's Avatar
    Mar 2016
    South Louisiana
    42
    Hi All!
    Under my current contract with PB (haven't started yet), I am slated for a single speed Hayward pump. I'm getting a raised spa with 8 jets & a 15X34 fiberglass pool. I will also have a heat pump (chiller)... not sure if that is a different pump or the same as all this pool equipment is confusing to me. Anyway, I've researched a bit on this site and found that Hayward seems to have lots of problems. My question is should I upgrade to a VSP ($700 more) and should I get a Raypak (I've seen suggested many times)? My PB is looking into it for me.
    Thanks for any incite ya'll can provide.
    15 X 34 Pacific Blue Viking Fiji, 3'6" to 6', 12,000 gallon with spill-over spa wrapped in stone, 2 laminars, noche travertine coping, & spray deck patio. Hayward Heat Pump, SWG
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Hayward versus Other; Single speed versus Variable speed--->Help Wanted
    I would definitely make the main filter pump a variable speed pump, you will likely save $700 in electricity costs the first year. Maybe you answered your own question about the heater?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Given south Louisiana electric rates, it might take longer than a year to pay for itself, but not by much.
    mas985's Avatar
    Pleasanton, CA
    11,737
    A SuperFlo VS would use about 45 kwh per month while a SuperFlo 1.5 HP single speed pump would use about 217 kwh with the same run time (4 hours). At $0.10/kwh, that is about $17 per month so it would take about 40 months of operation to pay the difference off.
    Mark
    DFW, TX
    24,497
    Thanks for the gut check on the numbers. I was figuring on saving about 1750 watts per hour over 8 hours at 10.25 would save about $43 per month. I rounded that up to 50 bucks and got to about 600/yr in savings.
    Tiger Lily's Avatar
    Mar 2016
    South Louisiana
    42
    I forgot to mention, Entergy will give a $250 rebate for the use of an Energy Star pool pump so I'm definitely going to use that to offset any cost increase. So really the pump would be $450 more.
