Results 1 to 7 of 7
Thread: Stain removal, Amazing.
    Alwayswantedapool's Avatar
    Jun 2015
    York SC
    200
    I had a few brown spots on my fiberglass steps and swim out. Tried a puck, nothing happened. Got some vitamin c, put a few in a piece of an old white t shirt, whacked them with a hammer a few times and then just rubbed on the stains. The stains came up almost instantly. Was simply amazing how easy it was to get them up.
    I think I will just wait and see what happens, if they come back I am thinking no big deal to just do the spot treatment every now and then. I am thinking a full asboric acid treatment would be over kill for these few spots. Any opinions?
    Thanks
    Mark, Pool: 30,000 gallon, IG Vinyl, Pentair Superflo Variable Speed 1.5 HP pump, Hayward S220T Sand Filter, Taylor k-2006 Test kit with speedstir. Dolphin Nautilus Plus.
    Hot Tub: Hot Spring Grandee 450 Gallons, Ace System (Salt water Chlorine Generator) Dichlor / Bleach method. Taylor K1766 Salt Test.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Stain removal, Amazing.
    Probably would be .if it was that easy to spot treat them. If it gets worse later, or more scattered out, you could think about it then.
    Essential Links:
    Jun 2015
    York SC
    200
    Now have to work on the bath tub ring around the steps and swimout. The rings are above the water line, assuming the previous owners didn't keep the pool drained like they should. Trying a 50/50 water and bleach solution to start.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    It could just be that a few grains of a fertilizer with iron fell into the pool. I know that in my previous pool, I had to be careful when fertilizing the grass near the pool.
    chiefwej
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Try the vitamin C on the ring to. Worked for me.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jun 2015
    York SC
    200
    Good idea, the 50/50 bleach and water didn't work. Will go try it right now
    Jun 2015
    York SC
    200
    No go on the vitamin c on the ring, it might have lightened it a little but very slight. Any other ideas? I did try magic erasers on it last year but that didn't work either. I think part of the problem it is very finely textured, so hard to get in those tiny crevices.
