Thread: Sorry for long absence but pool is a wreck now
    Dec 2015
    Citrus Springs,Fl
    11
    We were in a long move process and have now moved into the home with the pool.
    Hooked up pump and turned it all on and 3 of pop ups are only ones spewing any bubbles. The pool water has turned green and now is slowly turning blue again.
    Just purchased a pop up head removal tool and removed one. Does not make sense to me and dont get why all dont work. Can I open the module and blow air in to see of they work? They are these paramount type and any suggestions would be great.
    Also how do keep them on to put back in?
    Thanks for all the help
    In ground pool and was built in 2000 and is concrete I am guessing. It measures 14.5 wide and 24 long. It is not square nor rectangular. I have pictures if needed and can always take more. It is a Pentair system with propane heater Purex Triton, with Pentair filter ( cartridge) with a 1.5 hp sf1.1 pump( that is getting replaced) Will be new Pentair vs pump/motor 342000/01( on it's way here now) and test kit TF-100
    Casey's Avatar
    SW PA
    10,448
    Re: Sorry for long absence but pool is a wreck now
    I'm not familiar with these pop ups but maybe someone else is. We'll give ya a
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    that type system will probably need a call to the company who installed them or another pool equipment company.. wish i could help
    Dec 2015
    Citrus Springs,Fl
    11
    Okay well thanks for trying. It will be a learning experience( like our pond was )
