Results 1 to 14 of 14
Thread: Upgrading Intex Easy Setup Pool Pump
    Mar 2016
    Jacksonville
    2
    Hi everyone. I am new to this site and need advice from anyone who has upgraded their pool pump on the Easy Set Up Intex Pool. I have a 15' x 48' Easy Setup Pool with 1,000 gpm pump. It has three valves coming from the pool with a "T" for two that brings it from 2 hoses to 1 going into the pump and of course 1 coming back out to the pool. I want to upgrade to the 2,500 gpm pump. I know I will need some type of conversion kit since I am going from 1 1/4" to 1 1/2". Can anyone walk me through how to convert this pool to a better pump? Thank in advance, Jen
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,550
    Re: Upgrading Intex Easy Setup Pool Pump
    Honestly, with that size pump, I'd forget about adapters and cut out the holes for your fittings so that you can go with 1 1/2" end to end. There's really nothing to it, after you get over the initial nausea at the thought of taking an Xacto knife to your pool liner. Many of us here have done it.
    However, for the squeamish, search Amazon for Intex adapter.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,550
    Pentair IC40 SWG
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    I did the cutting, well kind of, I used a soldering iron it works awesome
    Mar 2016
    Jacksonville
    2
    Thank you! Glad to hear it's simple and easy to just cut the liner. My next dilemma is the pool that we have has two intake valves and one return. The two intake valves meet at a "t" coupler and go into pump as a single hose. I believe the new pump only comes with hose and fittings for one intake and one return. Anyone else have this problem and overcome it. I assume I could buy an extra hose and somewhere find a 1 1/2" T coupler. I have yet to find how to block the second intake valve instead of finding a T coupler that would work and the extra hose.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,550
    Intex sells the extra intake fitting and a cap you can screw on to close it off if you wish. But personally, I'd build a tee out of PVC and use them both.
    I built something similar for a few bucks that I use on the return side as a fountain/foot wash.
    Pentair IC40 SWG
    Jan 2016
    Milton, Ontario
    20
    If you get the adapter vs cutting the liner is it really going to make that big of a different on water flow or is it more stress on the pump?
    My pool: In-ground (22,000 gallons / 87,000 Liters), Pentair Sand filter, Carvin SaniClear 40 Salt Water System SWG, 1/2 Pentair WisperFlow pump, 400BTU Raypac gas heater
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,550
    I don't know about stressing the pump, but the cross section of a 1 1/2" fitting is 44% larger than that of a 1 1/4". I think you're wasting money on a 2500 gpm pump if you don't upsize the plumbing accordingly. There's a reason Intex makes them with the connections sized as they are.
    Pentair IC40 SWG
    Jan 2016
    Milton, Ontario
    20
    Quote Originally Posted by jeffchap View Post
    Very good point. I just hate the thought of cutting the liner lol.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,550
    I understand - I hesitated too. But once I did, it was no big deal. Just take your time making the cut. There's really not that much stress on the liner even with the pool nearly full. When I installed my thru-the-wall skimmer, I only drained to just below the cut. Talk about putting a hole in your liner!
    Pentair IC40 SWG
    Jan 2016
    Milton, Ontario
    20
    My anxiety level wen up just looking at that picture
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,550
    Ah, but once it's done, it's so worth it!
    Pentair IC40 SWG
    titleistseemore's Avatar
    Jul 2014
    Lodi Ca
    189
    I just used the adaptors to go from pipe thread to the 40mm intex thread and then installed a Hayward pump ...
    I bought them at the local pool store but you can also get them at Amazon ... they are by GAME 4560 40mm to 1 1/2 Inch Conversion Kit (For Intex & Bestway Pools) $8.95
    Amazon.com : GAME 4560 40mm to 1 1/2 Inch Conversion Kit (For Intex Garden
    Tim Jacobsen Lodi Ca.
    18'x48" Intex Ultra Frame (5700 Gallons)
    TF 100 Test Kit, Speedstir, & Sample Sizer. Liquidator Installed.
    Hayward C550 Cartridge Filter (55 Sq. Ft.), 1HP Powerflo LX Pump, Pool Rover Jr.
    http://www.troublefreepool.com/threa...uild-Questions
    Jul 2012
    SE Minnesota
    137
    I'd look into getting a Unicel filter to put in that pump and toss the Intex one, makes a world of difference. One filter will last you all season.
    Intex Ultra Frame 26'x52"
    Intex 2,500 gal/hr pump with Unicel cartridge filter.
