Thread: Sloped walls
    Nov 2015
    Lawrence, KS
    69
    Sloped walls
    We are in the process of inground vinyl liner pool construction and I was not aware that the walls had to be sloped. I've talked to my builder but I'm still a little confused. Especially in the deep end, there is a good 2-3 ft slope that cuts off some of the pool length. Any information is greatly appreciated.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,797
    Re: Sloped walls
    Yes, every vinyl pool I've ever seen had sloped walls in the hopper section. It seems in my mind that its basically a gravity thing. You are not building the pool base with something that will support a vertical wall when it is exposed (i.e. during construction and during a liner repair or water draw down.) Also, in the past many pools had sand bases which obviously wouldn't work vertically. Vermiculite could probably be installed vertically but again would not support any outside water/soil pressure without water to offset it.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Casey's Avatar
    SW PA
    10,421
    Re: Sloped walls
    Yes, all vinyl pool walls are sloped.
