Thread: Metals level a problem?
    TheBraLady's Avatar
    Jun 2015
    Concord, NC
    177
    I took a sample of both my pool and spa water to a local pool store just to get the metals tested. We filled our pool back in August with a fill service and of course have topped off as needed with our well water. Spa has been filled totally with our well water. I just ran Ahh-some thru it over the weekend, drained and refilled.
    So I would love some feedback about whether or not I need to add a sequestrant to the water with my levels:
    POOL:
    0 Copper
    0.4 Iron
    SPA:
    0.1 Copper
    0.3 Iron
    Thank you!!
    Pool Completed 8/2015 18'x36' Gemini shape 3.5' - 8', 19,200 gal IG vinyl, Hayward Max-Flo 1.5 HP 2-speed pump, Hayward Pro Series 300-lb sand filter, Hayward AquaPlus SWG, NO Autofill, Dolphin M400 robot, Taylor 2005 test kit, 434 gal Bullfrog A7L spa
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Metals level a problem?
    are you noticing any staining? splotching, discoloration?
    JoyfulNoise's Avatar
    May 2015
    13,258
    Iron only usually starts to be a problem when the levels are above 2 to 3ppm. Of course, the iron levels depend on the test procedures used. There are tests that simply measure dissolved iron and tests that measure both dissolved iron and total iron.
    For copper, you want levels below 0.3ppm or else Cu will start to stain. Same types of test are true for copper as well.
    So you can see that your well water is not metal free and will contribute to your total metal load.
    Do you keep your pool level with an auto fill or do you top off with a garden hose?
    Matt
    TheBraLady's Avatar
    Jun 2015
    Concord, NC
    177
    No - no staining at all - on neither the pool nor the spa...
    I top the pool off with a garden hose...
    May 2015
    13,258
    You might look into using some kind of hose end filter for metals (search online for them). Since you seem to have metals coming from your well, the last thing you want to do is add them to your pool. It's just a royal pain to deal with metals in pool water so anyway you can be proactive about it the better off you will be.
    I wouldn't worry about the spa. It's low volume and you should be dumping it periodically. Metal contamination there is really not an issue.
    Matt
    TheBraLady's Avatar
    Jun 2015
    Concord, NC
    177
    Great - thank you so much for the advice! I wondered about the garden hose filters. Off to Amazon!
