Thread: SWG - Worried about corrosion
    Feb 2016
    Houston
    323
    I'm still debating SWG or not. The hold back is possible corrosion. At the minimum distance our pool will be about 3' from the house and outdoor patio. Do we need to worry about any corrosion issues on the outside of the home or on or within the outdoor patio? Especially to the patio flood light, outdoor speakers, fan, can lighting, furniture? We will also put a portable fire pit and patio furniture on the deck close to the pool and don't want to have to worry about these as well.
    My pool thread. IG 31' x 20', 3.5'/4.5'/6', 8' spa, 4T moss rock WF/WW w/jumping rock, 7' x 11' sunshelf 3 bubblers, travertine coping, spray deck, Hayward equip: SwimClear 525 Cartridge Filter, H400 natural gas heater, Tristar Dual Speed EE pump 2HP, Tristar EE pump 1.5HP for water features, blower 2HP, Prologic P/S 8 w/aqua pod remote, Aqua Rite T-15 Salt System, Tigershark QC robot, networked Colorlogic LEDs 2 pool 1 spa.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: SWG - Worried about corrosion
    The only thing you might worry about is splashing.. at 3500 ppm you are way under ocean salt water of 32000 ppm or so if someone splashes (cannonball) you can use a garden hose and spray the porch/house and all will be good
    If you are really worried about something getting corroded you can use Corrosion-X Anti-Corrosion Aerosol and Lubricant, 16-Ounce and it is awesome..
    Amazon.com: Corrosion-X Anti-Corrosion Aerosol and Lubricant, 16-Ounce: Sports Outdoors
    JoyfulNoise's Avatar
    May 2015
    13,193
    There's very little to worry about, the extra salt you would add to the water will not matter. As a matter of fact, you already have a salt water pool if you use any form of chlorine or add muriatic acid to your pool water...every pool has salt in it. Most people are amazed when they switch to salt and buy 20 or 30 bags of pool salt only to realize that need half that amount because their water already has salt in it. I would not be surprised at all if you tested your water and found that your chloride level is already up above 1000ppm.
    Matt
    espejo's Avatar
    Nov 2014
    Kingwood Texas
    148
    I just switched to SWG (Pentair IC 40) and am very glad I did. I was using a Stenner pump for chlorine addition but hauling jugs since August was getting a little old. I plan on converting my Stenner to a acid addition device since I already have the connection in place.
    As JoyfulNoise points out when I tested my water after only using Bleach from August until February my salt in the pool was 1400ppm. I was surprised so while not 3200ppm it was almost half way there. I think ensuring you have proper water chemistry, so test often, is in my opinion more important.
    40x15 IG, 19,000 gallons, Taylor K-2006C, Intellichlor IC40, Pentiar 1.5 hp Intelliflo VS, Pentair 420 Clean/Clear Filter, Speedstir, Stonescape - french grey, Travertine Paver decking, Completed August 1, 2015.
    Feb 2016
    Houston
    323
    Thanks all, much appreciated. More confident now and I think we'll go with a SWG.
    Oct 2014
    DFW Texas
    78
    That and people obviously sweat in the pool... lol!
    7-10 year old In ground 20,000 gal, Aquabright ecofinish W/ Spa, waterfall and infinity jet, 60 sq foot DE filter, Single speed pump, Racer cleaner
