Thread: Is a Star Floor and/or porcelain tile compatible with Hydrazzo?
    Dec 2015
    Chattanooga, TN
    38
    I am considering putting a star floor in a portion of our pool and some porcelain tiles on the steps and the edge of the benches and swimouts. Since I understand Hydrazzo is a highly polished, sanded product, would that eliminate the use of either the stars or the tiles? Or do the Hydrazzo people polish around each tile or star point. Does anyone know?
    25 x 60 IG, 10' sunshelf, 24' sh, 26' dp; 57,600 gallons; 8' Jump Board; Hayward Equipment: 2 Sand Filters 36" Tank S360T2; 2 TriStar 5.0 HP FR Pumps SP3250EE; 2 Natural Gas Heaters H400FDN; OmniLogic; Sense & Dispense HL-CHEM; 2 SWG; pH Dispense Acid Feed System AQL-CHEM4-ACID; 2 systems work independently; Hydrazzo Plaster; TigerShark 2 Plus Commercial Robotic; 1 Spa and 3 ColorLogic lights; CoverStar automatic cover.
    Aug 2014
    Houston tx
    2,525
    Re: Is a Star Floor and/or porcelain tile compatible with Hydrazzo?
    I would be afraid that porcelain tiles would be slippery.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Sep 2015
    Tucson, Arizona
    86
    Can't give you a full answer, but at least one star floor manufacturer says to sand the point of light to make it shine more. So at least some sanding is apparently contemplated.
    This is from FiberStars' installation instructions:
    9. To change the light effect out of each fixture you may do the following to the remaining tip
    that is flush with the interior surface:
    A. Polish the tip with wet/dry sand paper. This will give you the least amount of
    light from the tip.
    B. Use a medium grade sand paper and sand the tip end. This will achieve a
    higher amount of light output than item A.
    C. Use a very heavy grade of sand paper and make the tip end extremely rough.
    The rougher the tip end is made the more light it will produce.
    Owner Build. 32x16, with 6x8 raised spa. Broke ground April 1, 2016, swimming July 18. Pentair Intelliflo VS + Whisperflo for Water features; Clean & Clear Filter 420; Master Temp Heater 400k BTU; Intellibrite 120V pool and spa lights; Regular ol' plaster.
    Dec 2015
    Chattanooga, TN
    38
    Thank you!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    According to that they would work. I agree with too much tile on the steps. Too slippery.
    Essential Links:
