Thread: Part numbers for Hayward multiport
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    I have a Hayward multiport and i need to order a new top half..
    I wonder if the one on it now is even the correct one.
    The top half now just says hayward vari flo
    The lower half (body ) say SP-715A 50
    It's a 2" D.E. Pool.
    Any body know the correct p/n for the new lid assembly ????
    Thanks..
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    Feb 2015
    Chandler AZ
    936
    Re: Part numbers for Hayward multiport
    I was unable to locate just the lid while doing a quick Google search.....
    Have a look here:Hayward Multiport Valve - 2 SP716 Parts - INYOPools.com
    The lid itself looks to be obsolete - you might need to order the entire top portion. Looks like you would also need to order the lid gasket separately (if you need a new one).
    The entire valve assembly (side-mount) may wind up being a better deal - as you get a few other parts (lid gasket, site glass, etc.: Hayward SP0715X62 Side Mount Pro Series Multiport Backwash Valve 2in.
    EDIT:
    Just noticed the second link says it's for a sand filter. A little looking around on that site or a quick phone call to them should get you the correct part number for yours.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Ordered one of these ..
    Sean Hannon
