Results 1 to 8 of 8
Thread: water level
    delfargo's Avatar
    May 2008
    some cornfield in central illinois
    86
    water level
    the opening process is coming along. finally got my ph down to 7.2, my shock pretty much held overnight last night (had it at 20, 18 this morning - close enough?) my only problem is this... i got it from dark green to "milky" rather quickly (a couple of days) but it's been at this milky state for a week now and doesn't seem to be clearing. i brushed the entire pool a few days ago and i've had to backwash a couple times a day, so i know the filter is working, but it just won't get any clearer. i was wondering if my problem may be the water level is too high. the instructions that came with the pool said the water level should be at "mid-skimmer". well, with all the rain we been getting here in the midwest, my water level is about an inch from the top of the skimmer. i haven't lowered it yet because i know once i can see the bottom i'll be vacuming to waste and i'll need the extra water. do you think if i lower the water level, it'll filter better and clear faster, or does it really matter?
    thanx again for the help.
    30' round above ground - 21000 gal. (shade ONLY in the evening),
    pentair dynamo 1.5 hp pump,
    pentair sand dollar 150 lb.sand filter,
    bbb method.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: water level
    Nope, not close enough. 1ppm or less.
    Try the DE in the sand trick, but not today. It can take a week or so for sand filters to clear up cloudy water after an algae bloom....but with a drop of more than 1ppm you aren't done shocking so it will take a bit longer.
    delfargo's Avatar
    May 2008
    86
    Re: water level
    "close, but no cigar" huh? darn ! o.k. then, i'll keep it up with the bleach.
    i did the de in the sand last year and it seemed to work. why not today?
    when should i do it? wait till it clears up more?
    also...any thoughts on the water level?
    thanx mom.
    bbb method.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: water level
    The main problem with the water level being too high is reduced skimmer effectiveness at removing floating debris. Since you are backwashing frequently, I'd just use that to reduce the level.
    11,969
    Re: water level
    Quote Originally Posted by delfargo
    thanx mom.
    Because everytime you backwash, you have to repeat the DE process, and you'll likely backwash again in the next day or so while your still shocking. So wait till the FC holds, backwash, then add the DE.
    Jun 2007
    NC
    255
    Re: water level
    Quote Originally Posted by frustratedpoolmom
    Nope, not close enough. 1ppm or less... It can take a week or so for sand filters to clear up cloudy water after an algae bloom...
    FPM's correct about the 1PPM or less, as usual! Remember that the "stuff" between the surface and the bottom that you can't see right now is going to get into the filter and/or has to be killed .
    You have to use the P.O.P that you have and let the filter do it's work.
    Terry in NC
    Triad Region of NC
    18x37 Vinyl IG (24,000 gal.), BBB & GoldLine AquaLogic PS4 SWG, Hayward 1 HP Superpump / Hayward Sand Filter / Polaris 280 cleaner / 6 deck jets / Sheer Descent Waterfall (in coping) / Brick Red Concrete Coping / Stamped Concrete Deck
    Lots of oak trees, maple trees, *and* leaves!
    delfargo's Avatar
    May 2008
    86
    Re: water level
    o.k...i'm gonna sound like an idiot here, but...... what does "p.o.p." stand for?
    bbb method.
    SW Indiana
    9,199
    Re: water level
    Pool Owner Patience
