Results 1 to 11 of 11
Thread: How to know if Cartridges are bad?
    Sep 2013
    San Rafael, CA
    38
    I have an old neglected StaRite 3 cartridge system. How do I know when I should replace the cartridges? Do I replace both of them at the same time or only the inner vs outer (is one a pre-filter for the other)?
    Per the pressure gauge on top (its a new one), the system is about 3 PSI when 'clean' and 5 PSI when I typically empty it. This is a new gauge that maxes out at ~15PSI.
    Note that I have 1.5" intake & returns, so that may impact expected PSI rates. When I kick on the booster cleaner pump, the PSI drops by 1-1.5PSI or so. Per the flow check valve, it runs about 40GPM.
    Thanks for the help on this great site!
    21K gal Plaster I/G | 1/2 HP Sta Rite main pump |StaRite 3 300 sqft cartridge |
    Ancient Kreepy Krauly Legend | 3/4 HP A.O. Smith Century Pressure Pump|Solar Pool Cover
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: How to know if Cartirdges are bad?
    the only time you "need" to change them is if they are ripped or the plastic is seperated on the bottom and top of the filter.. This all depends on you really, the outer filter if really dirty and a TSP cleaning does not bring it back to new it can be changed..
    If you want to get new one's that is fine but you dont have to
    ****thanks Mark****
    I changed TSP cleaning
    mas985's Avatar
    Pleasanton, CA
    11,737
    Have you tried a TSP soak and then an acid soak?
    Mark
    Sep 2013
    San Rafael, CA
    38
    Quote Originally Posted by mas985 View Post
    I have not gone the TSP path & Acid soak yet.
    I've had good results with a good hose out followed by 24hr Cascade soak + Borax mix - but not acid.
    I didn't have a good container for the big ole Sta Rite 3 cartridge. I do now. It is a nested cartridge style filter. The inner cartridge has some discoloration around the top 1/3 or so (where it sticks above the larger cartridge).
    Based on conversations with the previous homeowner, these cartridges could be more than 10 years old...she has no idea when they were replaced.
    After my latest activities (AA treat + pool opening + SLAM), I was going to head that route. I wonder if this is why my mustard algae kept coming back.
    What do people do with the acid water?
    @mas985 - what brand is your 2sp pump?
    Sep 2013
    San Rafael, CA
    38
    Quote Originally Posted by VTSoundman View Post
    Disregard question about the acidic water...duh...can just use some baking soda to neutralize. I do this with car batteries, why not this? heh...
    mas985's Avatar
    Pleasanton, CA
    11,737
    It's a Northstar wet end with a SuperPump 2 speed motor. AKA "Frankenpump"
    Mark
    Mod Squad pooldv's Avatar
    DFW, TX
    24,470
    Re: How to know if Cartridges are bad?
    If you do decide to get new cartridges for your filter check out Pleatco. I am very happy with mine, as are others. They have better flow, easier clean up, last longer between cleanings and they're cheaper!
    Jul 2013
    Fletcher, OK
    3,353
    ^^^^ 100% agree, I love my pleatco filters.. I have 2 for my Spa 100sf filters I just have not made the purchase for the pool
    Sep 2013
    San Rafael, CA
    38
    Anyone try the retrofit kit? Replaces the large & small filters with 3 smaller filters that claim to have to the same surface area. The pool guy on YouTube seems to really like them...and I think they are ~$30 cheaper too - supposedly has better filtration. I haven't verified prices yet.
    http://www.bestbuypoolsupply.com/ede...retro-kit.html
    Here is the URL
    http://www.youtube.com/watch?v=ylcO7jTZ9pE
    Jul 2013
    Fletcher, OK
    3,353
    that video is made by a guy who knows what he is talking about and does hundreds of reviews... like it says he has over 12 million views
    That looks like a great kit to change to and also that is how most of the new filters are being made mine included...
    good find
    Sep 2013
    San Rafael, CA
    38
    Quote Originally Posted by cowboycasey View Post
    good find
    I would agree - except now he is selling some stuff that he reviews on his site (- incl this I think). I've learned just about as much from that guy as I have on this site
    Something about folks that start selling products who used to simply do reviews makes me doubt their integrity. I think it comes from being burned a few too many times from being duped by digital/internet shills. I am not suggesting that he is now a shill, but now I will wonder if he is advocating a product for profit. I know, everyone needs to make a buck, but that is something I have a hard time reconciling.
