Results 1 to 19 of 19
Thread: Hayward Salt and Swim 3C
    Mar 2016
    San Antonio, TX
    10
    Hello,
    Fairly new to pool ownership but things have been going well I think over the past 6 months. We have an In-Ground pool (small at around 12K Gallons). Its got a SWG (Hayward Salt and Swim 3C) my issue is that even on the lowest setting It generates too much chlorine since we don't have much if any swimmer load since its still too cool. Is this a common issue? My other numbers seems to all be right where they should be but FC if left on the min setting climbs to around 6 or 7 at which point I turn it off and allow the levels to drop back down. It's kind of taking the whole automated chlorine away!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Hayward Salt and Swim 3C
    you can do 1 of 2 things
    change how long your pump runs: if your running 8 hours go to running 6 hours
    change how long your SWG runs: only turn your SWG for 4 of the 8 hours pump run time
    I see this is your first post, Welcome
    Mar 2016
    San Antonio, TX
    10
    My pump is a two speed and runs on low 22 hours a day and kicks up to high for 2 hours per day to run the pool cleaner. PB said their pump doesn't use much power on low and sure enough my bill increase was really small so thats how it's been running the last 6 months.
    I can turn off the pump using the switch but again its pretty manual. Sounds like I'm stuck just turning the SWG off and on every other day?
    Jul 2013
    Fletcher, OK
    3,353
    if your pump is automated "turns from low to high by itself" then you can do it no problem..
    1. let us know what equipment you have at your equipment pad... when we know what you have it can be changed..
    2. post a picture so we can see what you have..
    you really do not need to be running your pump 24 hours a day, most of us run about 8 to 10 hours a day to chlorinate with a SWG and filter... this will save you even more money
    Mar 2016
    San Antonio, TX
    10
    Hi,
    I'll see about getting a picture of the pad. I have a Century 3.5 HP Dual speed pump connected to an intermatic timer which switches it from low to high as mentioned. There is a manual switch mounted below the intermatic timer box which can turn the pump off and on completely for service and such. Otherwise pump is connected to a Hayward cartridge filter and the salt and swim 3C.
    12K Gallon IG built 9/2015 3.45 hp Hayward 2 speed with Hayward Cartridge filter and Hayward Salt and Swim 3C.Lamotte Color Q Pro 7 Plus.
    Jul 2013
    Fletcher, OK
    3,353
    ahhh low tech, that is perfect... you just need to change the time your pump runs.. I take it you SWG is connected to the same intermatic controller..
    when you turn the pump off does the SWG also turn off?
    Can you get the model number of the intermatic timer?
    Mar 2016
    San Antonio, TX
    10
    T106R is the intermatic timer model.
    The salt and swim is not connected to the pump timer nor the switch. There is a separate 110V outlet which the salt and swim is connected to.
    Jul 2013
    Fletcher, OK
    3,353
    so that is the reason they ran it 24 hours.. the good thing is you can change the run time.. at 1:05 on this video shows how to change your times.
    The bad, you will need another intermatic timer connected to your SWG... when you say 110v outlet is it a 3 prong plug in? if so see below if not let me know..
    this is what I would use Intermatic P1121 Heavy Duty Outdoor Timer 15 Amp/1 HP - Plug In Timer Switches - Amazon.com it is an outdoor rated 120v timer by intermatic that would allow you to plug in your SWG into it and set times to run..
    with this type of setup you would run you pump 1 or 2 hours on high
    EG: start at 0900 in the morning
    start low speed at 1000
    stop pump at 1600 (4pm) love my military time
    start your SWG at 0930
    stop your SWG at 1530 (3:30pm)
    Mar 2016
    San Antonio, TX
    10
    The way my pump is connected to the current Timer, there is no way to turn off the pump. The timer simply turns it from low to high and back again.
    I can definitely use the timer you linked to plug my SWG into although I'm not sure if it will pick up where it "left off" settings wise with the loss of power and re-power cycle. Something I can test.
    Jul 2013
    Fletcher, OK
    3,353
    it will, they are designed to lose power and turn back on.. you can do a 5 minute test and unplug it and plug it back in, it should return to the same xact setting it was at..
    if you do not mind the pump running 24 hours you can leave it just as it is and just turn your SWG off and on (try 6 hours at 50% and see what that does)..
    if the little switchs are missing you can get new ones 2 ON and 2 OFF Metal Trippers: Intermatic Timer Parts: Amazon.com: Patio, Lawn Garden these have a high speed on and a low speed on and 2 off trippers.. you can save major amounts of run time and power saving if you installed these.
    they are not really high and low speed trippers, they just turn one "side" (high) on then the other "side" (low) on then an off tripper
    Mar 2016
    San Antonio, TX
    10
    Quote Originally Posted by cowboycasey View Post
    Wait, maybe I am not understanding you. My switch already has the trippers (Green on tripper and gold off tripper) When the switch is in off position, it's on low and when it's in "on" it's on high. Are you saying there is another tripper that turns the whole thing (both legs) off?
    Above is my switch.
    Jul 2013
    Fletcher, OK
    3,353
    that is correct, you just need an "off" tripper to turn it off
    looks like 0630 high turns on
    0900 low turns on
    what I would do is buy those trippers and put an off tripper at 1400 (2pm) that would be 7.5 hour pump run time
    then run your SWG from 0700 to 1300 (1PM)
    see how your pool water looks and how much chlorine you have then adjust your times..
    up on pool pump time if you think your pool is not clear enough
    up on SWG % IE from 50% to 75% if you need more chlorine
    if you need more chlorine and do not want to raise % then change pump and SWG run time
    You can also use less pump and SWG run time that will save more, it all depends on the clarity of your pool
    this will save your electricity bill very much
    Mar 2016
    San Antonio, TX
    10
    From what I'm reading online, I don't think the above switch will turn off. It appears I need this:
    Amazon.com : Intermatic T10604R Pool/Spa Control Center T106M and T104M : Electrical Timers : Patio, Lawn Garden
    Jul 2013
    Fletcher, OK
    3,353
    **************Ok, I just zoomed in to your picture, it looks like you already have an "off" tripper***********
    is that correct? this has me confused... it should turn everything off, not just 1 leg of the power (high)
    has anyone else seen this???
    I am looking at that T10604R but I have never used one of those.. so I just dont have the knowledge on those.
    I use the Intermatic PE653RC Wireless Control System, so i can check it from the remote..
    someone will hopefully be along that can help with this
    Mar 2016
    San Antonio, TX
    10
    see the following link. Looks like I need that combo timer if I want to be able to turn pump OFF. I could however still try to do the other intermatic switch for the SWG. I'm debating buying the double mech switch since my pump also runs my water features.
    Intermatic Pool Timer Dual Speed Pump Timer - T106R - INYOPools.com
    Jul 2013
    Fletcher, OK
    3,353
    well that is why I was confused... knowing is half the battle, I thought that timer turned the pump on and off, not turn High to Low...
    SO the timer for the SWG will work for you and your pump will stay the same...
    I am not sure how you are on funds but I love my switch for my pump, high and low, SWG and lights you would need to get it rewired/installed but that should be pretty easy for an electrician..
    Intermatic PE653RC Wireless Control System for Variable Speed and Two-Speed Pumps - Sump Pump Accessories - Amazon.com
    Feb 2015
    Chandler AZ
    936
    In order to have both on/off and two speed switching you would need to add an Intermatic T104 timer in with your existing Intermatic T106 timer. The T104 could be in a separate enclosure mounted next to your existing T106 - both timers after the manual on/off switch.
    T106 - used for switching from high to low (existing)
    T104 - used to turn pump on and off
    Intermatic Timer 220 Volt Metal Enclosure - T104R3 - INYOPools.com
    And wire it up as follows:
    Mechanical Timing Controls For Two-Speed Pump Applications (Basic Wiring Information)
    I ~think~ you can also wire up the 110 volt SWCG to one of the 110 volt legs of the T104 timer - which will turn the SWCG power on and off with the pump. It should work, although I will defer to others who are more familiar with the NEC and your local building codes to determine if it meets code.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    Jul 2013
    Fletcher, OK
    3,353
    Thanks Gene, I had no idea that the T106 was used for speed changes...
    Feb 2015
    Chandler AZ
    936
    Ha - neither did I until I needed advice on my daughter's pump replacement: Pool pump advice.
    After having help from the experts here and a little Internet research, it became clearer.
    Gene
