Results 1 to 13 of 13
Thread: are there any pressure cleaners that don't use booster pump?
    Mar 2008
    Delaware
    40
    i have a 6 year old jandy rayvac pressure side cleaner that is worn out. it doesn't require a booster pump.
    i can't find any other companies/varieties on the market that don't require a booster pump. does anyone know of any brands? i'm not interested in buying another jandy rayvac.
    it's not that i hate the booster pump idea, but i wouldn't know how to instal it, electrically speaking.
    thanks in advance
    Thank you in advance for your help.
    Noctiss
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: are there any pressure cleaners that don't use booster pump?
    Polaris 165 is what my neighbor has, and he likes it.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    The Polaris 360 can also run without a booster pump.
    mas985's Avatar
    Pleasanton, CA
    11,743
    ThePoolCleaner also runs without a booster.
    http://www.thepoolcleaner.com/
    Mark
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    Quote Originally Posted by mas985
    I'm partial to both the Polaris models mentioned, but I also have heard good things about the Poolvernugen, noted above.
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    Guest
    Let's not forget the Letro Legend II. It's also boosterless!
    Mar 2009
    Auckland - New Zealand
    48
    what about a robot - theres the dolphin cleaners and another model easily available and both get good reviews
    neither need a boost and clean better than most
    Quote Originally Posted by budster
    My 'Poolvergnugen' does alright, but it doesn't like the shallow end at all... it gets there (eventually) and then hits the wall, lays down on its side and gose in circles until it finally reaches the slope to the deep end and then it rights itself..
    ... of-course, I have a kidney shaped pool with curved walls in the shallow end and I think that is what defeats it.
    20K gal, vinyl, 1 1/2 HP pump, 24" sand filter
    Mar 2008
    Delaware
    40
    Quote Originally Posted by dbishop0011
    thanks for the info on the poolvergneugen. i was about to buy one today online. now i'm not sure b/c my biggest pet peeve is when the cleaner doesn't get into the shallow end.
    i should probably rephrase my question to: are there any good pressure cleaners (without booster pump) that get the shallow and deep end equally clean?
    Noctiss
    mas985's Avatar
    Pleasanton, CA
    11,743
    I have thepoolcleaner 2x suction and mine gets to the shallow end just fine but it probably spends a bit more time in the deep end. The deep end has a lot more surface area than the shallow end so the cleaner should spend more time there. A lot depends on the shape of the pool and how you set up the cleaner. The adjustment of the float has an effect on not only how high it gets on the walls but also how much time it spends on the floor.
    Mark
    how much do these poolcleaner.com models run in price? I can't find the price anywhere.
    -inBamaNow
    16x32 Hydra Liner, Hayward 24" Pro Sand Filter, WhisperFlo 1HP Pump, Hayward CL200, AquaChem Test Kit =[
    mas985's Avatar
    Pleasanton, CA
    11,743
    Try here.
    Mark
    Mar 2007
    San Rafael, CA USA
    12,082
    I have a 4-wheel pressure-side Pool Cleaner and it gets to the shallow end, but it does sometimes get hung up at the edge of a ramp in the pool, though usually backs out from it when it goes into reverse. Overall, I'm happy with it, but my pool doesn't get exceptionally dirty.
