Thread: Fitting/re-plumb question w/pics
    Apr 2010
    Buckeye, AZ 85326
    619
    He all its been a long time since I've stopped by. I made a mistake this weekend but I think with some plumbing help I can get it repaired and back to normal with out to much trouble. The weather is warming here and we are starting to swim. I was using the water spigot that connects to my pool plumbing to spray off my decking and knock the dust off the patio furniture. When doing so I closed the valve to my return to get max pressure to the spigot and water hose. Well I got done cleaning, turned off the spigot but forgot to open the return valve. The pump ran for several hours like this and the water spigot either worked itself loose or was forced out of the PVC. I caught it before to much water was lost and any real damage was done. I tried screwing the spigot back on but it leaked then I bought a 3/4 inch PVC plug. It made it a bit better but it still leaked. So I think the threads in the plumbing fitting have been damaged. What do you all think is the best way to replace the fitting that the spigot threads into. I'm handy enough to do this without issue but I cant wrap my head around where to cut or to just replace the entire run?
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Re: Fitting/re-plumb question w/pics
    Just a thought because you didn't say, did you wrap the threads on the spigot or the plug with Teflon tape?. I have found that 6 or 7 wraps works for me.
    Angie M.
    AG, 26' x 52" Intex Ultra Frame, vinyl, 14667 gal. And LOVING it!!! Hayward S15922S 1HP, 2SP pump and Hayward S220T Sand Filter. Hard plumbed with PVC, added second return, intex SWG, Hydro Pool widemouth skimmer. Set up in May 2012!
    N.E. Florida. TF100 - Best investment EVER! (Well, for the pool anyway)
    Jun 2014
    15,269
    If you can't salvage the spigot fitting at the "T", then I would think cutting just below the "T", trying to save that remaining PVC exiting the pump outlet if possible. Then simply re-plumb back to the filter. You might even be able to do it without having to run that horizontal length so high. If you find the remaining vertical PVC run (currently with the "T") too short to work with, then consider re-locating the spigot fitting on the horizontal run instead? If installed on the horizontal run, you might consider unions in case you ever have to repair/replace the spigot in the future.
    Apr 2010
    Buckeye, AZ 85326
    619
    Thanks for the feedback. I did and do use teflon tape but its not doing the trick here.
    2' Powerfall
