Results 1 to 11 of 11
Thread: Sent wrong pool liner? ? Help
    Mar 2016
    Jackson sc
    4
    Ordered a new above ground pool. 27 round 54 inch wall. The problem I'm having is the liner bottom seam will not make it to the cove ( foam cove ) so in return the liner is not long enough for the wall.. Called the seller they said the liner would work but clearly on the box it reads 48 52.. claim it works on 54 inch wall also.. help I'm stuck. . All wrinkles are out of the bottom also. .
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,374
    Re: Sent wrong pool liner? ? Help
    Hi, welcome to TFP! I have a few questions for you. Is this an overlap liner or does it have a j-hook or bead that fits in a channel on the top edge of the pool? Have you started filling the pool with water? What was the approximate temperature when you started hanging the liner? Could you post some pictures of the problem?
    Love TFP? Become a
    TFP Supporter!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Also please edit your location to include the state, it helps to know the climate when giving some advice
    Mar 2016
    Jackson sc
    4
    Temperature was 70 degrees. .a little cloudy. . Liner is a overlap. . I live in lower state south Carolina. . Yes I did start filling the pool got about 6 inches that is when I noticed the wall trying to buckle. So I stopped with the water..
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    did you bring the sand cove in the middle 2 to 4 inches up the side of the pool?
    Swimming Pool Installation - What to Expect - 1 of 2 - YouTube
    at 5:18 it starts showing the sand, see how they push it up against the wall
    Edit: I see you have the foam cove, is the sand under it higher than the middle?
    banditig's Avatar
    Sep 2015
    Ohio
    466
    I have 54 pool and the liner box said 48-52. My wife pulled the liner about 2" over the top of the wall while I put the plastic strips on and temporarily tapped the top rails over that, working our way around. Then the liner stretched as we filled it (we also have about 1 foot deep end in the center).
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Mar 2016
    Jackson sc
    4
    Talked with gli liner manufacturer they told me it would fit but it needs to be professional installation. That there would be very little overlap. Gonna wait for it to heat up a little more. Than try again. . As for the pool bottom there is no sand it is a extruded polystyrene board.alot nicer bottom than sand in my opinion. .what would be the rule of thumb on liner stretch. . What %
    Jul 2013
    Fletcher, OK
    3,353
    ahhh, that is the same way I installed mine, LOVE IT
    liner stretch I have no idea about, sorry... I do know the hotter it is the more it will stretch..
    Mar 2016
    Jackson sc
    4
    It appears the liner needed a little more sun it started to fit in place. .. when can I install my top seat ledge ? While the pool is filling or wait until it's over half way full
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,379
    I would leave it off so you can get to the liner if you need to adjust it as it fills.
    Kim
    Casey's Avatar
    SW PA
    10,418
    I would leave it off til it gets to the bottom of skimmer n then put it on. You should have all your major adjustments done by then.
