Thread: can I replace existing jets with TwyrlyByrd jets
    Jan 2015
    austin/tx
    34
    Hi All, I am in the middle of a re-plaster job and have decided to inquire about replacing the older jets. I am just working with a plaster company so they don't really answer these types of questions. I am thinking of ordering new jets and giving them to the guys to install when they plaster. I have posted my remodel in the construction forum. IMG_0190.jpgWill they work with what I currently have?
    Austin, TX in ground 28,000 Midnight Blue regular pebble w/ abalone pool and spa, Aqua Rite Chlorine Generator, Cart filter, Jandy Niceless lights, Aqualink automation, Leslie's DPD test
    Jan 2015
    austin/tx
    34
    Re: can I replace existing jets with TwyrlyByrd jets
    After much searching and consult with any one who will talk to me, the answer is no. The best I can do is replace the eyeball fittings with flush mounts - which is still an improvement! Just thought I would post the answer for someone else who is looking for similar information.
    Jun 2015
    Charlotte, NC.
    82
    Sorry no one here had the answer, glad you posted back what you found out!
    - Matrioux
    2007 18K pebble IG pool - Wincor Pool Systems automation & SWG (under development) - DE Jandy DEL60 Filter - Jandy 1HP Pump - TF-100 Test Kit
    Dec 2014
    Houston, Texas
    134
    Not so fast my friend! If that picture you posted is what I think it is then the answer would be yes, yes you can. If you've removed the eyeball fitting and have 1.5" pipe there then the twirly fitting will glue inside the 1.5" pipe. This is all depending on how much pipe is there, may need an extender. The Twirly fitting sits 3/4" below plaster depth for a close to flush fit once plaster is applied.
