Thread: sta-rite backflow valve leaking from top
    Mar 2016
    paso robles ca
    3
    Hello,
    first time post - regarding a sta-rite swimquip 2" wc212-134p backflow valve.
    getting pool ready for summer and now have a decent leak coming from the top where the piston come throught the top of valve hosuing and joins the handle. i disassembled and took a look, o rings look ok,
    i cleaned off the piston but leak is still flowing.
    is this a problem new o-rings should take care of ? the valve is older - is it worth simply replacing the whole unit?
    any help is appreciated.
    thanks
    Mar 2016
    paso robles ca
    3
    Re: sta-rite backflow valve leaking from top
    ok i ordered the o-rings and will report back.
    Mar 2016
    paso robles ca
    3
    update - replaced the 2 main piston o-rings and now it leaks more. need to either purchase more parts for this valve or get new backflow unit.
    any suggestions ?> thanks
