Thread: Spots and Stains
    Jun 2011
    San Diego California
    88
    Spots and Stains
    I'm draining my pool (SWG) because over the past 5 years the CH level is finally so far out of whack I have no other real choice. Over the last year I noticed more and more the stains (blue color) and now spotting. They are generally all smooth to the touch, but have a couple dark spots that are raised lumps on the bottom. I've included some pictures now that the pool is draining and I can see them better. They look much worse when dry.
    Even with my CH too high to even measure by the end of last year, everything else I was able to keep fairly balanced by keeping an eye on it all the time. Before draining, these are the results.
    TA 100
    CYA 50
    FC 5
    PH 7.6
    CH 1000???
    Could not get a proper result for CH, as it was so high, but over the last couple years its been growing higher and higher from fill water. Two years ago I converted to SWG, and that's when I saw the first minor spots, but maybe that was just a coincidence?
    Any ideas on if these are calcium scaling, or something else? There seems to be three different types of stains; large blue color streaking, spots, and raised dark lumps.
    I plan to re-fill the pool right away, but if there is anything I can do while empty, I'd like to; such as acid washing any stains that may come up?
    IG, 13,000 gal, concrete, DE, VS Intelliflo Pump, Intellichlor SWG
    San Diego, Ca.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Re: Spots and Stains
    The splotches look like Calcium scale. The raised bumps are efflorescence. Use the search box to read up on it.
