Results 1 to 14 of 14
Thread: Filling up Intex pool
    Piper Mike's Avatar
    Jan 2014
    Bartlesville, OK
    200
    Hi everyone
    I'm filling up my 26 ft round above ground Intex ultra frame pool for the first time. I started filling with hose yesterday around noonish. It's now near 8 in the morning. It still is about a third filled or maybe even less. It's not leaking. I walked around it all yesterday checking, plus I went under the line before I started to add the water to check for holes. Is this normal for such a big pool to take so long?
    Thanks
    Mike
    Intex ultra frame 26'x52" above ground pool
    Intex ultra 18'x46" above ground pool retired
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Filling up Intex pool
    ohhh yes, I used 2 hoses and it took almost 24 hours... it also depends on you pressure and volume, I have about 50 to 70 PSI and a 2 inch supply coming to my house... with a 1.5 inch supply, 20 to 30 PSI and 1 hose may take 2 or 3 days
    Grab another hose and it will go faster but remember your filling over 16000 gallons
    Piper Mike's Avatar
    Jan 2014
    Bartlesville, OK
    200
    Thanks Cowboycasey! Yes only one hose. It's not yet a third up. Oh well. Too cold to do anything yet anyways but wait. Thanks again
    Mike
    Jul 2014
    Oakbank, Canada
    389
    Yup, my 16' takes almost 16 hours to fill with a garden hose.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,866
    Just a side note. If you are on a well, you will be doing your well pump a favor if you can run two hoses. It helps keep it from cycling on and off.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Don't be surprised when the water is green. Tap water is surprisingly green. It will clear up in a week or so.
    Piper Mike's Avatar
    Jan 2014
    Bartlesville, OK
    200
    I live in the city. As it is now with one hose, the rest of the hose water pressure is very little. I shut it off for an hour to run a quick dish washer last night, so don't this a second hose would give me any water thru out rest of house.
    Casey's Avatar
    SW PA
    10,421
    Any pics of that monster pool Mike?
    Piper Mike's Avatar
    Jan 2014
    Bartlesville, OK
    200
    Hi Casey
    I'll sure try. Lately I haven't been able to save a file small enough to get it to fit a thread
    Sorry unable to.
    DFW, TX
    24,450
    Upload the pic to photobucket, copy the IMG code and paste it in your post.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Use a host service, like Photobucket. Upload your photos, the copy the [IMG] link and paste it into your TFP post.
    I can't remember how long ours took, we started and stopped more than once.
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Like others have said, it takes a long time to fill. It's close to 15000 gallons and the hose can only do so much.
    Just a heads up tho, something to check out, you may be able to contact your water company and complete an affidavit so you won't have to pay sewer charges on the pool water. It runs about $90 in water to fill my pool (26' same as you). Sewage would have cost me an additional $135 if I had not submitted the affidavit. You give beginning and ending meter readings on the affidavit. Here, the water company gave me the numbers over the phone.
    Angie M.
    AG, 26' x 52" Intex Ultra Frame, vinyl, 14667 gal. And LOVING it!!! Hayward S15922S 1HP, 2SP pump and Hayward S220T Sand Filter. Hard plumbed with PVC, added second return, intex SWG, Hydro Pool widemouth skimmer. Set up in May 2012!
    N.E. Florida. TF100 - Best investment EVER! (Well, for the pool anyway)
    Piper Mike's Avatar
    Jan 2014
    Bartlesville, OK
    200
    Thanks for the advice Angie! I already called, no such luck
    Anyways, it's an inch from being filled. I shut the water off this morning so we could do laundry and run dish washer. Started it up again tonight at 6 and about an inch left to fill. So it took about 2.5 days to fill. It dropped to below freezing last night so water is still only in the 50's. My daughter still wanted to go swimming tonight. She went up to her knees on the stairs and went in the house. Thanks for all the comments
    Mike
    Casey's Avatar
    SW PA
    10,421
    I remember opening my pool one April and my daughter harrassed me endlessly to go swimming, I finally got sick of her pestering me n told her to get in. She did not last but a quick minute!
