Thread: Stains in pool and trying to avoid re-plastering
    Mar 2016
    Waco, Tx.
    2
    Hello. I'm hoping someone has some advice for me. I have a gunite pool built in 2011. The first few years I had it I really didn't know what I was doing and am still limited in my knowledge and rely on the local pool supply stores to help me keep things in line. My issue is that I have a lot of stains in the pool from poor chemical management. The local pool store came out and said an acid wash would not get the stains out. Is my only option to re-plaster the pool?
    18,000 gal in ground gunite
    Built in November 2011
    Jan 2012
    'burbs of Augusta, Georgia
    7,359
    Re: Stains in pool and trying to avoid re-plastering
    Do you have one of the two recommended test kits (Taylor's K-2006 or TF-100, either available from TFTestkits.net) and can give us a full set of test results:
    FC, CC, pH, TA, CH, CYA
    Perhaps we can help diagnose what the problem is, and why your still newish pool is in bad shape?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,031
    Are they metal stains, or are they perhaps patches of Calcium scale? Scale will be rough to the touch; when they're really bad, it's like grow-your-own sandpaper that can cause road-rash, especially on knees and elbows. Scale is also not gleaming white the way you imagine. Not Hollywood teeth white; usually tan or greyish.
    An acid wash will remove scale.
    Post a picture or two. Best time to try photographing is early morning when it's bright but before the sun hits the surface, and the water is still.
