Thread: Liquidator conversion not working
    Jun 2014
    Casselberry, FL
    11
    Hey all...I've had a 4 gallon Liquidator for a little over a year and I finally got around to doing the conversion to 3/8 everything today. I got all my parts delivered and installed everything...had a heck of a time getting the new fittings to fit into the larger PVC holes without them leaking (teflon tape wasn't enough so I added plumbers epoxy around them to seal them up. However, now that nothing is leaking, I can't seem to get any flow going. The "out" connection is sucking air to point where my tubing is compressed, the flow indicator is full of water, but the float is at the bottom. I'm attaching a link to a video I took if it helps...any help would be greatly appreciated.
    https://youtu.be/Rn_vo0cnpbY
    Thanks!
    18-20k gallon in ground pool w/gunite surface
    Leslie's Crystal Clear II DE filter - DE-LE-42054 - 96gpm
    Hayward Super Pump with AO Smith UST1102 1.0HP motor
    Non-SWG
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Liquidator conversion not working
    Sounds like the outlet float is stuck or you have the inlet and outlet reversed. Lifting the outlet float should start flow.
    Jun 2014
    Casselberry, FL
    11
    Quote Originally Posted by JohnT View Post
    Well I've got the tank filled high enough where the outlet float is fully open and the flow indicator itself is filled to the top with water...for whatever reason though it won't flow out of the flow indicator and into the tube.
    Non-SWG
    Ellington, CT
    263
    Looks to me like you got the flow indicator plumbed backwards. Check out page 9 of the Liquidator manual.
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
    Jun 2014
    Casselberry, FL
    11
    Quote Originally Posted by laprjns View Post
    Ugh...that's exactly what it was...everything is working perfectly now...thanks Laprjns!
    Non-SWG
